inadyns setup?
  • joes
    • Apr 2009
    • 9
    inadyns setup?
    hi all
    can some help me put the right info into inadyns i have a no-ip acount
    in user name i have put the user name i us to get into no-ip is this correct?
    in the password i have used the password i use to get into no-ip is this correct?
    in Alias i have put the account ( ght****@hopyo.org ) i have created at no-ip is this correct?
    in system i dont know what to put the default is ( [email protected]) what should it be
    any ideas on how to get it going would be appricated
    joe
  • red devil
    • Oct 2008
    • 690
    all correct so you should be good to go there, dont forget to save setup and start inadyn
    • 3axes
      • Feb 2010
      • 5
      I have also same porblem
      when i purchase the box it was working fine but after the factory setting its not working,all entries in indyana are perfect but its not working
      is there some file are missing?
      • joes
        • Apr 2009
        • 9
        to red devil
        thanks for you help it works 100% now i just needed the little nudge in right direction
        joe
        • red devil
          • Oct 2008
          • 690
          im not surprised m8, after factory reset you loose everything
          time to start again
          • 3axes
            • Feb 2010
            • 5
            Sir i want to clear the point that after the factory default i reinstall every thing again,now i am using my ip updater through pc.
