Converting a .ts file to avi?? please help!!!
  • hitman07
    • 171
    Hi folks, im ready to go mad ere . but is there a way to convert a.ts file to avi any way as i think i have tried everything to no avail. please help!!!
  • Devilfish
    Administrator
    • Feb 2008
    • 7872
    Try this program...
    AutoGK Homepage - THE tool for XviD / DivX conversion
    • hitman07
      • 171
      I have tried that programme but i keep getting the error EXCEPTION: Audio is not found.
      i cant think of anything im doing wrong. i really need to get this fixed ol
      • westkill
        • 2378
        never tryed it but found this
        http://www.nchsoftware.com/prism/index.html
        • gazz10
          • 1015
          Auto Gordian Knot will convert directly from .ts to .avi. It's absolute simplicity to use and you can specify the target size of the resulting .avi file so they will always fit on your media. For example, if you're recording a 6-part series, you can specify that each avi file will be just one sixth of a DVD. The results are high quality. You can also specify a target quality, if you prefer.
          Having said that, I wouldn't seriously store recordings without removing adverts and start/end padding first. There are certainly ways of doing this without cost, but I use VideoRedo and would wholeheartedly recommend spending 30 for the Plus version (rather than the more expensive TV Suite). Workflow then is:
          1) Open .ts file in VideoRedo. Remove ads and padding.
          2) Save edited recording as mpg.
          3) Convert mpg to avi using Auto GK.
          Steps 1/2 typically take about 10 minutes for something like a channel 5 movie. Speed of step 3 depends on your PC, but on my (pretty average dual core) laptop it typically takes about 125% of the running time of the recording. I usually programme a batch of conversions to run overnight.
          One question - why do you want to convert to avi
          • hitman07
            • 171
            I just have a little collection of films on avi and i thought that its the best way. would u recommend anything else to me maybe??
            • cimi1234
              • 17
              Hello !
              Try Super on this :SUPER ? .
              Is very fast and light tool ! I'm very happy with it.
              Regards!
              Cimi
              • hitman07
                • 171
                I have tried that also. im recoding from my dreambox and then transferring to my pc and then i need to join the files and then convert them to avi
                • micron123
                  • 24
                  .TS to .AVI
                  I use VLC media player to convert AVI to TS to play on my Dreambox. It works just fine. It will convert your DVD's to .TS also so the Dreambox will play them.
                  It should be no problem converting the .TS to .AVI using it. Just stream it to a file (myfilm.avi) by selecting the Codecs you want to use.
