Help
  • dark84
    Probe number one
    • hitman07
      • 171
      #17
      i have done the dns and i just want to know which port to forward
      <--hitman07 added 101 Minutes and 38 Seconds later...-->
      i have forwared ports 21, 23, 80 and have the no ip set up and i still cant acces it. am i still doing something wrong?
      • Curious123
        • 2591
        #18
        When someone types in the dns hostname of your dreambox on the web, your router needs to pick that up and redirect it to the dreambox via your internal ip address. For example if your host is hitman.dyndns.org than the dyndns.org site will recognise that address and send it to your modem which in turn sends it to your router which in turn must translate the request and send it to specific device i.e your dreambox. So you need to go into router and set up a rule or service which when it recieves a request from hitman.dyndn.org send it to i.e 198.168.1.100 the ip address of your dreambox. Port 80 is open by default for web access on your router .
        • hitman07
          • 171
          #19
          im using the bt home hub. do i do this in the same part as port forwarding?
          • Curious123
            • 2591
            #20
            Sorry but don't have a BT Home hub so can't really help tell you the exact details for the configuration.
