Linux server help
This topic is closed.
  • fes_786
    • Sep 2009
    • 389
    Linux server help
    i have been reading up that the longer u keep cccam running some times it takes longer to respond
    ecm times .etc
    i would like to make a script that restarts cccam every day around 4am
    so i would need to create a file e.g. CCcamRestart.sh and put it in scripts folder
    then would the following code do the trick:
    echo "Restarting CCcam.x86 : $date" >> /emu/log/RestartCCcam.logecho "cccam... restarting"/emu/cccam/CCcam.x86 & exit
    chmod it to 0755 to make it executable
    and then i would need to put following into crontab:
    00 4 * * * root /emu/script/./CCcamRestart.sh >>/emu/log/RestartCCcam.log 2>&1
    could some 1 check this and tell me if it would work??
  • gunes30
    hi if any one want dreambox card shering server is send me msn NO EMAILS MATE
    AND NO CARD SHARING EITHER
    • Manic01
      • 5117
      Not on here mate, against the rules.
      • mm009b
        • 221
        Originally posted by gunes30
        hi if any one want dreambox card shering server is send me msn EDIT BY ADMIN
        i dont think you can post that here mate !
        • Manic01
          • 5117
          Certainly cant, breaKING rules, You should edit it out of quotes as well my friend.
