Dreambox Signal is 61-70 % is this too low?
  • bubbles69
    • Feb 2010
    • 1146
    #31
    oh yes Jesus i never seen so slow.... at least you know what it is now m8.. my ECM time from my own server is 0.169 to 0.192 i never seen a sever with times like yours m8 must be from abroad at perhaps hop 2 or 3
    • damiensk
      • Apr 2010
      • 201
      #32
      them ecm readings are horendous, mines usually about the 0.250 mark, on the odd occasion it goes up to over 0.300, but it still doesnt glitch on 28.2e. and im on a hop 2, wih a non uk server.
      you need to sort you server out, with them readings, do you ever get a picture??
      • billy2
        • 1381
        #33
        increase my clock speed time from 5.5 to 6.8Mhz and no glitching so far will see how this goes
        please press the little red THANKS tab
        if I helped if not press the green tab to tell me to f**Koff
        • billy2
          • 1381
          #34
          well it worked for a bit, sorry i did not hold of for the HYRO 9900 HD or the th800 HD on my HD channels my ecm times are from 0.345 to 1.460 on some channels on a hop2
          • bubbles69
            • Feb 2010
            • 1146
            #35
            0.345 to 1.460 that is terrible that would cause constant freeze..!
            you need a good steady server with around 0.159 to 0.179 at hop 1
