save to usb stick and not hrd drive?
  • Curious123
    • 2591
    #16
    Originally posted by wannelly
    Hi mate, its a 4 gb usb stick,when u say format it in the dm800 I'm not sure if iv done that, how do u do that, well I made a backup of my image on my usb stick and I think the dm formatted it for me to make the backup,maybe I'm wrong mate, so how do I format it and thanks for reply
    I am using the Pli image on my dm800, press Menu > Setup > Harddisk > Format or it might be initialise.
    • Wingnut
      • 376
      #17
      jsut tried that mate and all seems ok then but till unable to save for some reason, is there a way to change my recording to usb as maybe its trying to save elsewere, im using gemini 4.70
      • DaDiDo
        #18
        Yah me too , i have the same problem , i initialized my USB the then tried to record but not succesfull and still the same problem , i am using Gemini 4.70 , and i tried 'Nabilosat Black Hole V0.12' but both didn't work .
        if someone had this problem and resolved it plz help us.
        • westkill
          • 2378
          #19
          if your usb stick is formated in the dm800
          try this
          press video twice
          press menu
          switch to file list and press ok
          press ok on parent directory
          scroll to list of storage devices press ok
          should give you option
          lower usb slot
          usb stick
          internal flash
          at the bottom of screen should be green button to ok
          new recording path
          this should work
          • DaDiDo
            #20
            yes it works ,thanks .
            • Wingnut
              • 376
              #21
              yeahhh, worked a treat mate, thanks u
              • damiensk
                • Apr 2010
                • 201
                #22
                would that be same if i used an external hdd?
                i have a usb stick, but the 4gb wouldnt last very long,
                when your recording a hd channel!!!
                thanks in advance
                • tichmc9
                  • 60
                  #23
                  Didn't work for me after pressing video twice when i press menu nothing happens
                  • avatar7
                    • Apr 2010
                    • 6
                    #24
                    hi, im trying to record to my dm800 with dreamelite bh1.3. ive mounted a usb stick but i cannot record. just keeps saying hdd not present. has anyone else had this problem.
                    • cboyer
                      • Feb 2012
                      • 271
                      #25
                      im using dreamelite too mate and i cant get this to work when i press video it brings up recorded video but when i press again it doesnt do a thing
                      "I've got it made. I've got a wife and a TV set -- and they're both working."
                      • abr
                        • 108
                        #26
                        doubt you will get any answer from avatar 7
                        the date of the post is nearly 2 years old
