at the races
  • scoot1690
    • 90
    at the races
    hi guys can anyone help i can get audio but no picture on both channels any ideas how to get video thanks in advance
  • father ted
    • Feb 2008
    • 1389
    tbh im the same but berley who lives over the water from me gets the video too and i gave her the bouquets wonder if its region thing?
    • milkybarkid
      • 105
      press the green button and change the pid!
      • red devil
        • Oct 2008
        • 690
        the dreambox has trouble getting attheraces, apparently its a tuner problem,
        but as said if you change the pid you will get the interactive feed only on the other hand a tm500 will get it no problem
        • SGTFlipFlop
          • Sep 2009
          • 1002
          If you have a Dreambox 500 press the green button and change the PID to PID 0208
          If you have a Dreambox 800 its a little bit more difficult, Open Dreamboxedit, Load up your bouquet, Find At the races and change the Video PID to 520, Save and upload to your Dreambox
          Happy viewing
          • scoot1690
            • 90
            hi
            thanks a lot mate thats it sorted now i should have said it was a d800 thanks again
            • bubbles69
              • Feb 2010
              • 1146
              Happy viewing
              Changing vid pid to 520 not work on dm800hd
              • SGTFlipFlop
                • Sep 2009
                • 1002
                Believe me it does, A scan might show 2 At The Races, Edit the one with 9364 SID
                • bubbles69
                  • Feb 2010
                  • 1146
                  Soz m8 was about to edit it, as channel pid is showing 518 when view channel, pid its just i edited so many times in dreamboxedit even one i receive the settings from the box it shows its edited to 520 vid pid but is not when channel select any ideas?
                  • bubbles69
                    • Feb 2010
                    • 1146
                    here is screen shot of what i retrieve from box
                    • SGTFlipFlop
                      • Sep 2009
                      • 1002
                      Here is mine, No other settings set apart from Video PID
                      • bubbles69
                        • Feb 2010
                        • 1146
                        tried all that but when i select channel and view pic it shows its using 518.. im well confused now
                        • SGTFlipFlop
                          • Sep 2009
                          • 1002
                          How are you changing it? Edit it Dreamboxedit, Save and upload to your box, Reload settings.
                          • bubbles69
                            • Feb 2010
                            • 1146
                            a thousand times m8,, i retrieve settings from box its all correct, pid 520 just for some reason the channel is overriding the default channels settings and choosing the pid from stream 518
                            • Tvaddict
                              • 47
                              Tick the "P" flag box in dreambox edit mate. This forces the box to read the correct vid pid (520)......
