CCcam Info PHP
  • sammy pro
    • Apr 2010
    dreambox
    hi, sorry please any one can help me to make sever for the dream box? and where i can get the cccam?
    • opsmonkey
      • 5379
      #17
      sorry no server talk here.. CCcam can be downloaded via the expert panel (blue button on your remote)
      Curious - I'm using "CCcamInfoPHP_v0.8.6 Modified by KTT Dre@mTe@m" with Windows 7 and IE8.. like BD i only run CCcamInfo on its own, no other IE windows open
      • Curious123
        • 2591
        #18
        Originally posted by SatSearching
        Ensure you have no IE windows running at all, then launch CCcam Info PHP.
        The newer version has always done this to me, but making sure I don't have IE running first makes it work,
        SS
        Your suggestion worked for me. Sat & Ops Thank you.
        • bubbles69
          • Feb 2010
          • 1156
          #19
          Best cccam viewer here for windows,,
          i use v1.2.1 but just new version released this morning im just about to install it..
          PhanTomDark_SaT_CCcam_info_v1.2.2
          RapidShare: 1-CLICK Web hosting - Easy Filehosting
          • zmrki
            • May 2011
            is this working on 64bit?
            • MrFug
              • 880
              #21
              Yes. Compatibility isn't really an issue these days. Win 7 64-bit can run all 32-bit programs.
              • southpaw
                • 2233
                #22
                downloaded new file from here
                Download PhanTomDark SaT CCcam info v1.2.2.rar from megaupload.com - Filestube.com - download everything
                but my A-V programme flags it up as a worm threat
                finally got it here , as the link above not loading for me
                • olindo
                  • 6
                  #23
                  I installed this version (portable), but not know how to exchange the default ip to my dreambox..?
                  default is : 192.168.1.10
                  where to make changes the username, password.. and ip of my dream..?
                  • smirnoff_rules
                    • 8603
                    #24
                    C:\Program Files\CCcamInfoPHP\htdocs then open config in notepad and change ip address to your box
                    might need to install full program
                    • olindo
                      • 6
                      #25
                      I installed this now.
                      Have again problem.Open C:\Program Files\CCcamInfoPHP\htdocs is folder 192.168.1.10
                      rename this folder to 192.168.2.6 (ip dreambox)
                      If open the program in CCcam info see the ip 192.168.1.10 !!!!
                      how to change...
                      second, where change username and password..?
                        Did you save the changes? No need to change anything else in config.
                        • smirnoff_rules
                          • 8603
                          #27
                          edit this line in config
                          $CCCamWebInfo[] = array("192.168.1.102","16001","root","dreambox"); // for CCcam webinterface with user and pass
                          • firestorm
                            • 1550
                            #28
                            Has any one ever got this to work on a mac?
                            tried crossover tried the terminal method with no joy
                            • olindo
                              • 6
                              #29
                              where is the "config" and whom program use to open this ..?
                              • olindo
                                • 6
                                #30
                                ok now............
