Telnet login incorrect HELP
  • jaykay4407
    • Apr 2010
    • 35
    I am trying to change the username and password on my dreambox, I am using DCC using username 'root' and password 'dreambox' but it tells me that 'Telnet Login Incorrect'
    Has anyone any ideas, its the first time I have tried this so it hasn't been tried before.
    Try using telnet in windows or putty to telnet. type in username and pass then type in passwd to enter new password
    • jaykay4407
      • Apr 2010
      • 35
      Thanks but tried puttytel also and still get the same message 'Login Incorrect'
      Any more ideas?
      Thanks in advance
      • Curious123
        • 2591
        Any more ideas?
        Thanks in advance
        Looks like someone's already changed your root password.
        You can reset your dreambox password using dreambox remote:
        1.install tuxbox commander using addons button
        2. Start tuxboxcomander
        3.go to in /var/etc/ and open the file passwd
        4.press 4 on remote to go into edit mode.
        The first line is root:*****:0:0:root:/home/root:/bin/sh
        where the ****** delete it (by using remote arrows to move cursor right and then pressing volume minus)
        delete *** until upto :0:0:root
        and press ok and exit -> save
        the first line should look like this after the edit
        root::0:0:root:/home/root:/bin/sh
        then login with user root and password leave empty
        you could telnet and change the empty password with your own so known can easily hack into your dm box.
        • jaykay4407
          • Apr 2010
          • 35
          Thanks ever so much for this but, when I get to add ons, I'm guessing that I select 'manual install' and then go to 'var' I can see a folder called 'tuxbox' with 3 more folders inside it called 'config' 'plugins' and 'scce'
          I don't know what to do next.?
          Thanks in advance
          • immy002
            • Apr 2012
            dm500 help
            hi im new to this dm fourm can some one help me with login to dm500 i dont hav a passwd for it
            • immy002
              • Apr 2012
              ps i cant delete the passwrd mentioned above
              • alotmentman
                try factory reset mate ....or flash box should take back to orignal settings
                • alotmentman
                  Originally posted by singhidiogee
                  I tried setting up Dream Box 500 with DreanUp 500 and got so messed up , everything is black now , I can't even get it to do anything , I'm new at this , so don't know what a person has to know to even help me , or am I at the end of the line . any Ideas would sure be appreciated , I just joined today , sounds like it , huh ??
                  relash it mate start again
                  • singhidiogee
                    • Jun 2012
                    singhidiogee
                    also I set up drmbx to TV and all I can get is " no signal " the remote wont even work the box , unable to get red or green light with remote , reboot many times but only thing it says is " no signal "
                    • singhidiogee
                      • Jun 2012
                      singhidiogee
                      going back over my steps , I clicked on "erase entire flash without Bmon" thinking I had to , to flash new IP, can that be rectified ??
