Hi i found this plugin it,s for enigma1 it gives week epg not tested i don,t have enigma1 box to test it,s a tar.gz file after you extract it
Weekepg3.1b-uk
forgive me for being silly but is a 500c an enigma1 box?Wavefield Ds 55cm at 13E 19E and 28E receiving everything out there on 2 dm800hd
previous life dm800hd and 500c on cable
screw you nag3
I had a good play about with this on my dm500c using Dk v1.1.
It seems to only want to show radio bouquets.
I changed the offline epg path from /hdd/weekepg to /var/mnt/weekepg so that it would use a shared folder on my PC. No matter what channel I selected it always returned with a blank page and didn't show any epg.
It's not ideal because the dm500 doesn't have enough memory or a hdd/usb to store the epg on so you need to have a shared folder on a PC or NAS to store them. But I couldn't get it to work anyway, even when my dreambox is connected to my router and it has full internet access.
Maybe this is only for UK Sky and not cable!
back to the drawing boardWavefield Ds 55cm at 13E 19E and 28E receiving everything out there on 2 dm800hd
screw you nag3
Hi mateI had a good play about with this on my dm500c using Dk v1.1.
yep this is only for sat boxes it show radio bouquest cause the channel that sends epg stream in uk is a radio channel so the plugin will tune into that channel to download epg.
Please use this version for skyUK
as i packed it with all UK channels and setted for sky UK
as for memory issue you can just select the channels you wanna the epg for i have had this running for several weeks on dm500 and is a cool plugin, i personally prefer epg imbadded into enigma but at moment this is only possible for skyIT maybe next nab image ?????????
ps:I dont know how cable stream work (i never owed a c receiver)if someone got more info it may be possible to convert this plugin for cable receiversLast edited by ^^MaXiMo II^^; 13 October, 2008, 11:01.::::>>Nabilosat<<::::
BlackHole projectComment
