downgrade 2.14 cccam too 2.1.1 can some1 explain thanks
  • psxchipper
    • 35
    i have a server running on 2.1.4 works fine but haveing problems with the spiderbox on hd so was told too downgrade too 2.1.1 i noticed on pli i can use the 2.1.1 but if i do this i will loose the details on my 2.1.4cccam info or can i just copy details from that too the 2.1.1
    there saying the 2.1.1 cccam works fine on these boxes for hd without probs but the 2.1.4 seems too glitch and hd does not work good on them,
    whats the best way too get this sorted and yes i have allready backed up my 2.1.4 cccam if theres a prob whats needed regarding this thanks
  • deffc0n
    • Aug 2009
    • 894
    CCcam 2.1.4 work very good all HD channels on SKY UK/Geramny/Italy etc.
    Maybe you have something wrong ?
    downgrade is very easy you must uninstall new version and install 2.1.1.
    What you have box ?
    • psxchipper
      • 35
      the spiderbox hd dont work well on 2.1.4 but does on the 2.1.1 and the server is a dreambox 500s and thats working fine but hd not running good and everybody showing as 100% so it must be a hd prob on the 2.1.4
      will the c lines still work on 2.1.4 even though im downgradeing too 2.1.1 as others are set too 2.1.4
      • damiensk
        • Apr 2010
        • 201
        yes pal, i doesnt matter what version you have the line will still work, or lets say in the past it has worked for me.
        my server also confimed this
        • psxchipper
          • 35
          damiensk so you had the same problem what did you do just put the 2.1.1 on and add your details again ?
          • bubbles69
            • Feb 2010
            • 1156
            Only this is with cccam 2.1.3 and lower it wont read 0963 card, so its ok if you are not sharing that card, just overwrite the cccam 2.14 file with the 2.1.1 program file, no need to touch the cccam.cfg
            • psxchipper
              • 35
              yes i am shareing and was told it should be fine but your saying it wn't ?
              • ITS A SCAM !
                • Oct 2008
                • 1140
                Sorry to hijack this a little bit.....Will Newcs read the card ok, and then 2.1.1 ?? I am thinking about downgrading my Debian server from 2.1.3 to 2.1.1 because if the same spiderbox problem ( thanks bobi....NOT !!!)
                • bubbles69
                  • Feb 2010
                  • 1156
                  yes newcs and cccam 2.011 will read nds card...
                  Spider boxes have a bad reputation like the technomate 6900 for breaking up stick to clone dm800 and 500
                  • bobi
                    • 83
                    True i confirm. ...good point.
                    but to add somethink more Spiderbox Read and share like server the cards it self.even the white card...
                    Has no any issu with 2.13 and 2.14....anymore after the laetest patches.
                    Not every one know haw to build servers and can be even some one have problem ,..They are not many but thye esist but still is not spiderbox problem.
                    • bobi
                      • 83
                      WHATS IS TRU is TRUE
                      TM have problem with CCcam
                      But WHAT IS NOT TRUE IS NOT TRUE
                      SPIDERBOX NO MORE problems ,,Inform your self...
                      lates patches has no any issu with CCCam a part of some one have problem with their server but they are not many...
                      • bobi
                        • 83
                        Is not Bobi fault...you like to have
                        2000 people in your server not PROFESIONAL//
                        learn more about servers programes ..
                        Maybe you know only one Kind of DEBIAn they are many of DEBIANs and not even DEBIANS but many other more...
                        But looks more then you dedicate your time to learn, you like to atack Bobi...
                        I am not offendiing you M8....but if you and few people can not doit mean you are not many...what about 5000 other owners they have no problem !?
                        If you Box is Faulty lets change m8 is better sulution....or if you do not beleve...I can gave you like even if you hate me . of my server 2.14 or 2.13 with cone you like ...and you try after we talk...OK!?
                        • manxspud
                          • 1768
                          ffs here we go again ....
