Dreambox 500 hd or VU+ DUO ?
  • Kennyken
    • Apr 2010
    • 78
    Im just looking for the most stable box which has no glitching or tuner issues.
    Also looking for the better better picture quality too
    I know the vu is more money and has hd capabilities etc etc etc.
    But just looking for a stable. glitch free box
    What you all suggest ?
    cheers lads
  • father ted
    • Feb 2008
    • 1389
    i have the vu+duo and can highly recomend it ,its more than just a box ,flash took 3 mins via usb,stuck my flash pen in with movies on it played them (avi,divix)vlc loads of things
    • av2008
      • 156
      I had the same issue, I ended up with a VU in the end. Its stable. However its not great at controlling my motor and its very big. Other than that the PQ seems similar to the DM800HD so its ok. I would recommend the box.
      I cant comment on the 500HD but i was really tempted. Its not a bad little box spec wise.
      • Kennyken
        • Apr 2010
        • 78
        Oh i dont need to worry about motorised dish as im fixed. and how do you flash an image onto this box via usb ? Im only used to dreamboxes and flashing via browser or null cable
        • av2008
          • 156
          Originally posted by Kennyken
          Oh i dont need to worry about motorised dish as im fixed. and how do you flash an image ?
          As Father Ted said above just unzip the files to a fat 32 formatted USB in the correct directory, switch off the vu from the mains, plug the usb in the front and switch the VU on, 2 mins later and its done. It will tell u to remove the usb and reboot.
          You can also do it via a null cable and probably ftp, all the interfaces are the same as DM's
          • Kennyken
            • Apr 2010
            • 78
            Originally posted by av2008
            As Father Ted said above just unzip the files to a fat 32 formatted USB in the correct directory, switch off the vu from the mains, plug the usb in the front and switch it on, 2 mins later and its done. It will tell u to remove the usb and reboot.
            Does it glitch like the dm800 clones do on discovery hd and sky sports 1 hd etc?
            Really tempted to buy this box and keep it for many many years
            • av2008
              • 156
              No, its perfect in that respect. I have both boxes so I can compare.
              • Kennyken
                • Apr 2010
                • 78
                Sweet.. does the box feel like it will last? as its gonna be the most expensive stb i have brought to day so i want it to last like i said?
                • av2008
                  • 156
                  I had the same feeling, its the most expensive box I ever bought too.
                  As for the quality I cant really say, Its not flimsy and the components inside look to be of a high quality. Its Korean made, not Chinese so its a bit better. The remote also looks like it could take a bashing. It has a sturdy casing and is large like a tank so it wont overheat.
                  Its impossible to tell how reliable it is because its so new, If they will fail they will fail after a year or two. Its just too early to tell.
                  • Kennyken
                    • Apr 2010
                    • 78
                    Yeah thats what im scared of as if it does fail after two years i might as well of got a sly hd subscription!
                    • av2008
                      • 156
                      True I suppose but I still have a sky sub,
                      Anyway if it fails im sure a fix would come out cos its so popular. I just hope it will be popular for the next few years anyway so support doesnt die.
                      Anyway goodluck with your decision and hopefully your new toy!
                      • Kennyken
                        • Apr 2010
                        • 78
                        thank you
                        • bubbles69
                          • Feb 2010
                          • 1156
                          V + duo all the way...!!! i have 2 in my house..!!
                          • Kennyken
                            • Apr 2010
                            • 78
                            Really good is it ? Worth the 400 Notes ?
                            • alunfennell
                              • Oct 2008
                              • 1525
                              It has to be the V + duo beats the dreambox 500 HD duo beats the dreambox 500 HD hands Down as its more like the 800 - 8000 HD with the twin tuner.
                              If comparing the soon to be released V + solo & dreambox 500 HD, i would go for the Dreambox simply because of the history of support for images & applications.
                              The V + duo is not realy in the same class as dreambox 500 HD and are not a like for like comparison the Solo will be more simular to the 500 HD..
                              V + duo & solo will / are a very good receiver
                              **The Worlds Best Interactive F1 Strategy Game**
