Gemini 4.5
  • foz
    • 37
    Gemini 4.5
    have read about genini 4.5 is out and killing boxes !!!!
    i take it that these boxes have not had the macs changed to: 00 09 34 xx xx xx ?
    i have had gp 4.3.1 running on clone with mac changed for months now, and thinking about flashing 4.5
    is 4.5 checking anything else apart from mac?
    i have alps tuner
    safe??????
    your thoughts guys
    foz
  • Devilfish
    Administrator
    • Feb 2008
    • 7872
    Why risk it...??? Gemini is not THE only image.
    • firestorm
      • 1550
      i ran gemini for years but after the clone bomb i changed to nabil and i would not go back its far better and who knows what trick gemini will try next
      • odedbor
        i am using this program with dreambox 800hd =no problems at all!.not so friendly ,but all others are more o less the same.
        • kopkidda
          • 122
          I have Gemini 4.2 on my Dreambox,its a clone, would you recommend moving to Nabilosat?Have you got the firmware I need to do this and a guide please?
          • Sicilian
            • 168
            Which Dreambox do you have?
            D I S C L A I M E R My right to post information is protected under the rights for freedom act. In all instances, information discussed here on my posts are either hypothetical in nature, out of general curiosity, common knowledge, public knowledge, or role-play. Any use of the collective descriptions and shared knowledge from any of my posts are at the sole discretion of the reader. I am not responsible for what you do with it.
            • Superman
              • 520
              Hi KopKidda, i personally would use the Niablosat 0.8 DM500S image as this is my favorite. However 4.6 Gemini Non Bomb is a good stable image also.
              • Bonesy
                • 655
                Niblosat beats gemini hands down
