Version 0.7 of 24/03/2010 - should support all larger resolutions except square.
-added support for EPG
-added support for Timer-events
-timer management
-added possibility to control the receiver such as rebooting, restarting Enigma, standby, wakeup and shutdown
-added Streaming (see second post for more information)
-fixed issue with text-boxes not being visibile when using touchscreen-keyboard
To see WMDR in action (using a pre-release of Beta 0.7), watch this video posted by XDA-user ajocius on YouTube:
[ame=http://www.youtube.com/watch?v=z2o3E5aaOEY]YouTube - WMDR - Dreambox Remote (with streaming to HD2)[/ame]
Background: After on-going discussions in this thread regarding an application to control remotely the Dreambox, I decided to write an application to accomplish this request.
In above thread, a very simple and crude beta-application was posted. Now, the application has evolved further and therefore I reckoned it was more appropriate to open a new thread in this area which is meant for Window Mobile applications.
Extra Information: The Dreambox is a series of Linux-powered DVB satellite, terrestrial and cable digital television receivers (set-top box), produced by German multimedia vendor Dream Multimedia. It's "kind of" of open-source which has led many "teams" to develop so called "images" for this receiver as an alternative to the original one furnished by Dream Multimedia. In addition, many other hardware manufactures have produced their own receivers (some of them are actually clones while others are not) using the same concept of the Dreambox i.e. Linux-powered. The Dreambox has evolved during the years and many models are present on the market. The first ones are/were using a firmware called "Enigma" but, more or less, with the introduction of High Definition TV, a new firmware was released, namely "Enigma2". One of the "revolutionary" features of the Dreambox was that you can connect it to your local network and this opened up a whole new word compared to ordinary satellite-receivers. To get further information, just google for Dreambox or look it up at Wikipedia.
Background for the application: You can read the original thread mentioned above to get an idea why people wanted an application like the one I am releasing. In a few words: since you can access the Dreambox (or any other satellite-receiver based on Enigma or Enigma2) through your local network or through Internet, there are many things you can do remotely (at work for instance) such as handling timer-events, read EPG etc. The ideal way of doing it, especially if you don't have access to a PC, is to use a handheld device. It was brought to our attention, that there are plenty of applications to do what mentioned above already available for download on the Appstore for iPhone.
So, it was suggested to write a similar application for Windows Mobile. And here it is, still in beta although with quite a lot of features implemented, even Streaming-support.
Current Features:
-Remote Control
-Bouquets-/Channels-lists from where you can:
1) change channel
2) view EPG
3) set timers
-controlling the receiver (Shutdown, Reboot etc)
-streaming
-Supports set-up of multiple profiles (e.g. At work, home, bedroom)
-Supports set-up of multiple streaming-profiles (Local LAN, WLAN, mobile)
Known issues:
-is not compatible yet with old WebIf (1st generation) of Enigma2
-chinese characters do not appear correctly (perhaps already resolved)
-in 320x240 version when setting up Enigma-profiles, you might need to click twice in the various textboxes.
Features to implement in upcoming versions (not necessarily in this order):
- SMS (Send shortmessages to the TV-Screen)
- proper error handling
- other ideas/stuff
- user-suggestions (your feedback for improvements)
- re-design the remote-control using png-images instead of jpg which should make the application a bit smaller (and require less memory)
- resolving above mentioned issues
- other bug-fixes
- support for other receivers - requests I have received are for D-box2 and IPBox HD (non Enigma)
- cosmetic issues
Requirements:
-Compact Net Framework (2.0 should be sufficient)
-an Enigma-based receiver such as the Dreambox, IPBox etc..
-for streaming, please see second post below
Installation:
Note: I have not made any CAB-file.
1) download the zip-file attached to this post and extract the files on your computer.
2) Copy the files into a directory of your choice on your device (internal or
storage). The files must be in the same directory.
3) Run WMDreamRemote.exe. The first time, you will get a message
saying "No connection....".
4) Choose Preferences/Profiles from the main-screen and ADD a new
profile inserting your data. Put the flag on default for the profile you use the most.
5) Then click Save Profile.
6) Go ahead if you wish to add other profiles.
7) You may delete my dummy-profile "home" (only after having added your own though) using
the Del-button. NOTE: It's important that there is always one profile present (with Default selected)
otherwise there might be unexpected errors
8) On the main-screen, you can now use the remote-control by selecting its button
9) You may also see a bouquet/channel list by clicking on its button. However, the first time the list will be empty. Therefore,
10). Go back to Preferences/Profiles and select the profile you want to use. Now select the
button named "Create Bouquets for this profile". This will take a minute or two. It will download
your bouquets and channels from your Dreambox. Do the same for each Profile you create.
11) Now you can scroll your bouquets ad channels.
12) Set up streaming-profiles (3 dummy profiles are provided for Local-LAN, WLAN and mobile) - see second post for more information
There might be some unhandled error-messages occasionally. They are mostly due to connection-problems. Just click on continue and retry unless you have indeed a permanent error with your connection.
Please test it and let me have your error-reports, feedback and suggestions for improvements. Please also indicate which device, Dreambox (or similar receiver) you are using and which image.
I must also express my sincerest thanks to XDA-user ajocius for:
-giving me access to Enigma2,
-his superb beta-testing,
-sharing his knowledge about streaming
-and of course for the great video he posted on YouTube (see above).
I have also attached some screenshots.
This is it for the time being.
-timer management
Current Features:
-Remote Control
1) change channel
2) view EPG
3) set timers
-streaming
Known issues:
- other ideas/stuff
- other bug-fixes
- cosmetic issues
Requirements:
Installation:
