A tip for people having motor power problems with their dreamboxes.
  • 215liverpool
    • 69
    Hi peeps,
    Just a tip that may help people who have motor power problems with their Dreamboxes.
    I've found that swapping the two pin (euro) plug that comes with the DM for a UK 3 pin plug has completely stopped my motor issues.
    You can pick the up the figure of eight power leads with a 3 pin UK plug on the internet quite cheaply.
    Not quite sure why but it's fixed it but hey I'm not complaining.
    Just thought I would share this with my fellow dreambox users
    Hope it helps someone
  • alunfennell
    • Oct 2008
    • 1525
    How is that !
    The power cable from the power supply has only two wires + & - introducing a three pin plug gives you the option of ground, but there is no ground wire into the power supply !
    If you theory is correct then by simply grounding the receiver by connecting a small wire from the chassis and ground it to a wall or solid floor would give the same effect, or by grounding you Satellite dish & Motor would also work.
    The only other thing that makes it work is the fact the + & - wire when connected when connected to a three pin pug give the correct power alignment to the power supply, the two pin plug and work either way maybe it not supposed to.
    Interesting post 215liverpool
    **The Worlds Best Interactive F1 Strategy Game**
    • 215liverpool
      • 69
      Originally posted by alunfennell
      How is that !
      Well I used to plug my dreambox into the mains using the 2 pin plug through an adapter. So maybe it was my adapter that was the problem.
      Just thought it would be interesting for other people to know.
