Change your dream remote code for 4 different Boxes
  • joesoap112
    • Sep 2009
    • 16
    If you have more than 1 Dreambox and wish to have each remote work each box without interfering with the others
    this is a little tutorial which may be of help to some.!!
    You can now have 4 different Dreamboxes with different remote codes.
    Download Multi Remote Control Layer Plugin
    Install and select one of the 4 different settings 1to4 as you require (NotDM8000)
    Ok that .
    Get out and go back in .
    Make sure its saved!!on Number you selected(not still on Multi setting)
    Then go to Remote and do the following!!
    First, you need to "unlock" the RC.
    This must be done in the following way:
    1.) press the Dream-key (the upper one)
    2.) press shift (next to the power button) until the RCU blinks two times,
    3.) now, without mistyping, enter the following numbers: 9 - 8 - 2
    now the RC has to blink four times. If it blinks only two times, the RC was already
    unlocked (and is now locked), so just repeat the procedure.
    Now you can choose the "level":
    1.), 2.) like above,
    3.) Press the following keys: 0 - 0 - 3 - 1 for level 1,
    OR 0 - 0 - 3 - 2 for level 2,
    OR 0 - 0 - 3 - 3 for level 3,
    OR 0 - 0 - 3 - 4 for level 4,
    now the RC has to blink two times. if it blinks only one time, the RC was not unlocked.
    now you can lock the RC (with the procedure above) again if you like.
    Please note: You are doing this on your own. If you mistype anything, you can set
    options which cannot be reset without a cable to the PC. If you only use 982 and 003x,
    nothing can happen, but be careful.
  • .: JaCkPoT :.
    Retired Sat TV Addict
    • 5611
    Nie one mate
    ___________________
    In the good old days, I had
    DM800s HD
    Openbox S10
    TM500
    DM500s
    90cm FortecStar dish
    Maxx 110cm Dish
    Technomate 2300 Motors
    • papi1962
      • Jul 2010
      Ok that .
      Where is possible to download Download Multi Remote Control Layer Plugin
      Thanks for answer
