The attached is for Enigma2 boxes which use a Ppanel for user scripts. Just unzip it and place it in the /etc/ppanel/ directory.
The tool kit includes:-
Disk temperature reports
one off or regularly to a log file
Disk SMART parameters
Modify fstab
Swap file management
mount swapfiles from disk or disk-1
unmount swapfiles
find existing swapfiles
report active swapfiles
delete swapfiles
create 64Mb swapfiles on usb or internal disk
reports and tasks
List contents of /tmp directory
Disk %age use
Installed devices (not necessarily mounted)
Mounted devices
Running processes
Network connections
Available memory
User environment
Automount info
Force ethernet connection
Show ethernet connection state and type.
Check hardware clock
Reset hardward clock from kernel system clock.
Check software clock
Process management
Turn task manager on/off
List scheduled tasks
Remove scheduled tasks
set up crontab for user root
sample task - schedule recording of disk temperature
View/truncate report for disk temperatures
Real techie reports
Display kernel parameters
Display loaded kernel modules
Display loaded Enigma python hooks
Modify fstab
unmount swapfiles
delete swapfiles
reports and tasks
Disk %age use
Mounted devices
Running processes
Network connections
Available memory
User environment
Automount info
Process management
Real techie reports
