Why no Prem Direct?
  • buzzbomb
    • 106
    Why no Prem Direct?
    For some reason when I scanned in Astra 19e I did not pick up any Prem Direct. Then tried manual TP scan and still nothing ie scanned 11720h and got the 4 regular Prem channels (says 5 services scanned but can only see 4) but no Direct channels. Signal and Quality are good etc so it must be something else. Any ideas.
    VU Solo2 (clone) , Alsat GBOX V3000 positioner, 1.8m Precision motorised dish. Invacom twin 0.3 LNB, Image Blackhole 209 clone safe. Quad core Android TV box running XBMC and many other Appsl
  • Devilfish
    Administrator
    • Feb 2008
    • 7872
    Do you mean Premiere Sport Portal? Are you just looking at the wrong place in the list?
    11719.50 H - Txp: 65 - Beam: Astra 1G DVB-S (QPSK) - 27500 3/4
    • .: JaCkPoT :.
      Retired Sat TV Addict
      • 5611
      Prem direkt transponder is the weakest on the sat i think so make sure your dish is fully well aligned. The other prem channels will turn up as unnamed or a series of numbers.
      ___________________
      In the good old days, I had
      DM800s HD
      Openbox S10
      TM500
      DM500s
      90cm FortecStar dish
      Maxx 110cm Dish
      Technomate 2300 Motors
      • buzzbomb
        • 106
        Devilfish yes it is TP65. According to lyngsat I should also pick up direct 1,2,3,and 4+. My other box picks them up no bother but on the dreambox it appears to only pick up the 5 standard channels
        Sadiq it is picking up 5 other prem channels on the same transponder so it cannot be a signal problem.
        • thered
          • 4915
          just a stab in the dark m8 have you got the channel but you cant view whats on if so you need to press your green button for the sub services it will bring up another few channels
          this is where the footy is
          • .: JaCkPoT :.
            • 5611
            Make sure your not searching scrambled only or in the menu as prem direkt portal is fta.
            ___________________
            DM800s HD
            Openbox S10
            TM500
            DM500s
            Maxx 110cm Dish
            • buzzbomb
              • 106
              Thanks thered (guess u were a bit relieved last night when Riggs did the necessary) I guess it is possible they could be under another obscure name(on my other box they scan in as pg 2424 etc)
              Is there any way I can view the channel list and also see the sat frequency at the same time.
              My image is nabilosat v08 maxvar
              • .: JaCkPoT :.
                • 5611
                Chances are as i have already mentioned is that the channel names are numbers or named unnamed.
                ___________________
                DM800s HD
                Openbox S10
                TM500
                DM500s
                Maxx 110cm Dish
                • Curious123
                  • 2591
                  Could be you don't have the latest channel settings. Have you tried loading the captains settings with the latest satellite.xml file?
                  • buzzbomb
                    • 106
                    Curious123 sorry for delayed response but have been away for the weekend. No I have not tried captains settings as I was not sure how to go about it. Was looking for it on the Nabilo server but could not find it. Have never loaded anything into a dir on the DM so I have been reluctant to try. Can u tell me step by step how to do it.
                    • Curious123
                      • 2591
                      Last time I checked Nabilosat had removed the captains settings from their download server. If you google for it you should find it easily and use a proggie called dreamboxedit to load it to your box.
