DK 1.1 adding a new CAM
  • sKeith
    • 13
    Hi,
    I was reading through the DK 1.1 thread but it seems mainly filled with people happy with the pre-installed evocamd cam.
    I was hoping to skip a little reading my being direct.
    I installed DK 1.1
    held info for 3 sec and found preinstalled evocamd ok.
    I then used blue KAOS Panel button and opened the addon manager.
    I downloaded all the cccam files from delilfishs post http://www.digital-kaos.co.uk/forums...-0-10-a-10729/
    and popped each into /tmp and used local install.
    I would then try to use the the info for 3 sec chooser again but never found
    extra cams in there. to make matters worse, when i used the tool to uninstall it removed the pre-installed evocamd.
    I can sucessfully telnet in and copy the cams into the bin folders and chmod 755 them and start them manually. I do not know how to get them to show up in the GUI info for 3 sec place though.
    Can someone please supply quick help here.
    I also tried the files in the recent mgcam thread too
    Thanks in advance.
  • Devilfish
    Administrator
    • Feb 2008
    • 7872
    If your box is connected to your router, you can download emu from the addons server.
    Yellow > Manager Suite > Addons Manager > DK Server > EMU
    If not, I've attached it here. Copy the .tbz2 file to the /tmp folder and use the manual addons option to install.
    • sKeith
      • 13
      oops, can you confirm, I think archive is broken.
      EDIT: Above archive is all good now. Thanks Devilfish.
      I'll try it on the box tonight, and try to learn what its doing
      • Devilfish
        Administrator
        • Feb 2008
        • 7872
        Hmmm...maybe the forum doesn't like tbz2 files.
        I've zipped it up, try again.
