Glitching
  • hitman07
    • 171
    Glitching
    Hi folks, Im asking for help as when im watching my dreambox on cs everything seems fine when my pc isnt on. My internet is running great but when i have both them on at once then it begins to skip a bit. any help will be appreciated
  • cauliflower69
    • 261
    If its on NDS (s*) thats normal unless you can get a good server. Also do you have ports forwarded properly on your router and can you set it up that the dm has priority of the bandwith.
    • hitman07
      • 171
      im not sure the ports are forwarded correctly to be honest. can you tell me what ports i need to forward. im using a bt home hub router
      • cauliflower69
        • 261
        Can you go online with your box ?
        If so goto start, run msconfig on your comp and ping the ip address of your dm
        • hitman07
          • 171
          Im at work at the minute but i will try this when i get home later. i will let u know how i get on. thanks
          • hitman07
            • 171
            here are the results of the ping:
            bytes=32 time<1ms TTL=64
            • cauliflower69
              • 261
              so all must be good then. Make sure you forward ports 12000 afaik for your dreambox
              • hitman07
                • 171
                ok i will give it a go when i get home. thanks again
                • hitman07
                  • 171
                  should i be able to access my dreambox by typing in the ip of the box from my work pc??
