Dreamdroid Android Client for Enigma2
  • alunfennell
    • Oct 2008
    • 1525
    Dreamdroid Android client for Enigma2-based Dreamboxes
    Features:
    * Control your enigma2-based Dreambox with any android mobile
    * Browse channels and EPG / Zap to channels and/or recorded movies
    * Set new timers (from EPG or manually) and edit or delete exisiting timers
    * Send messages to your box
    * Use your android phone as virtual remote
    * See what's currently running on your box
    * Search the EPG of your dreambox
    Dreamdroid is a open-source android client for enigma2 based Set-Top-Boxes.
    The dreamdroid project ist hosted on sourceforge, sources are available via svn.
    Dreamdroid is licensed under the Create-Commons Attribution-Noncommercial-Share Alike 3.0 Unported License
    The project page on sourceforge can be found at
    Dreamdroid is still in an early stage of developement (alpha, not beta) and may therefore still cause a "Force-Close" here and there (please report them to me).
    Changelog:
    2010-07-13 - 0.3.6 - beta
    - Add possibility to Search EPG, also accessible via hardware-search key (if there is one)
    - Also show service name epg_item_dialog (because it is variable when showing results of EPG-Search)
    - Some minor other changes
    2010-07-12 - 0.3.5 - beta
    - Add basic possiblity to display "Current Service" (use options menu to reload)
    - Add possibilty to start movie playback via a movies context menu
    - Reorder Buttons in main menu
    - Fix SSL-Connectivity on Froyo (broken pipe)
    - Allow apps2sd on Froyo
    - Fix some minor bugs
    2010-07-06 - 0.3.1 - pre-beta
    - Move SimpleHttpClient instanciation to SimpleHttpClient.getInstance(SharedPreference)
    - Handle non-202 HTTP-Status correctly in SimpleHttpClient
    - Add hasError() and getErrorText() methods to SimpleHttpClient
    - Improve Error-Messages throughout all Activities using SimpleHttpClient (which are all except DreamDroidPreferenceActivity)
    - Rename DreamDroidPreferences to DreamDroidPreferenceActivity
    - Some minor refactoring
    - Fix some bugs in some AsyncTasks
    - Add "Login" Checkbox to preference screen for enabling/disabling the use of login credentials - disabled by default (please check if you need credentials for your connection to work!)
    - make "root:dreambox" the default credentials
    - fix Typo in Volume-Minus-Button in VirtualRemote
    - bump version to 0.3.1
    2010-07-05 - 0.3.0 - alpha
    - Add VirtualRemote (looks best on HDPI-Screens)
    - Disable ldpi-support for now (needs some adjustments first)
    - Some smaller fixes
    2010-07-04 - 0.2.9 - alpha
    - Some refactoring
    - Improve layout of main-menu in landscape mode
    - Enable sending of messages
    - Enable Device-Info
    - Add option to delete recorded movies
    - Improve movie list layout (now showing more information)
    - Add "Current Event" Option to Servicelist Context-Menu
    - Some (or maybe quite a lot of) code-cosmetics
    2010-06-25 - 0.2.5 - alpha
    - First public alpha release of dreamdroid
    - Browsing channels and EPG and adding/changing/deleting timers (manual or using EPG) works (no support for tags an locations, yet)
    - Supports only configuration of a connection to a single box for now (ssl working)
    **The Worlds Best Interactive F1 Strategy Game**
  • h1_to_1
    • Aug 2009
    • 22
    gr8 app, works a treat
    • longgboy
      • Feb 2011
      • 4
      I've got a db and the app, and i'm trying to tie the two together, i've looked at my router and put the ip it's given the db into the app, and i'm looking for the port, iv'e tried 21,80, and I think it was 60001 or something like that from what I read yesterday.
      But they still ain't connecting, what port is the db opening to connect to my router?
      Can anyone point me in the right direction to get these two to talk to each other?
      ta in advance
      • 00360362878
        • Mar 2010
        • 488
        have you downloaded the app from the android market
        • 00360362878
          • Mar 2010
          • 488
          also have a look at this tread mate
          http://http://www.digital-kaos.co.uk/forums/f39/androiddreamer-andr-free-android-app-streaming-local-lan-3g-176543/?highlight=tilleke
          • longgboy
            • Feb 2011
            • 4
            Hi gents,
            Yes I have the app from the mkt,
            the link given doesn't work
            • 00360362878
              • Mar 2010
              • 488
              Dont know why the link dont work, but type (tilleke) in the search at the top of the page, you can find it then. Also mate you also need to download vplayer, if you havnt already. It works fine on my HTC.
              Good luck.
              • longgboy
                • Feb 2011
                • 4
                i've found his thread, and i'm working through it, thanx
                • jagga303
                  • 13
                  I have got this Dreamdroid on my htc phone and it works fine with my Dreambox. I can connect to the dreambox using wireless network but not using the mobile's internet. Is this suppose to work only on wireless network, or can it work using the mobiles internet?
                  If anyone can shed some light on this and if its possible, how to do it.
                  Also I have vlc player but I cannot watch streams on my mobile from the dreambox. How can I make this work?
                  • kangochad
                    • 29
                    I also use this app, it's brilliant.
                    To enable control over WAN rather than LAN you would most probably have to setup port forwarding to your DM via your router and IP Address.
                    Have a look here for your router and have a read.
                    I'm not sure which ports you would have to forward to but I am sure someone else here will be able to shed some light.
                    Good luck, let us know how you get on!
                    • jagga303
                      • 13
                      Anyone able to help me please. I can use all functions of dreamdroid except streaming. Please can someone give me step by step clear instructions on how to get this working, its beginning to do my head in.
                      • jagga303
                        • 13
                        Please can someone help me with the above?
                        • jagga303
                          • 13
                          Someone must know the answer to the problem above, anyone?
