i am a total newbie at this i am trying to get fausto to work, having no joy can any point me where i can some easy to learn tutorial
dreambox and fausto emulator info needed
FAUSTO KEYS EDITOR/EMULATOR/LOGGER/CLIENT/SERVER
Installation: not needed to uninstall previous version, just run Fausto V1.XX setup.exe
Fausto Emulator compatibilities:
*XML file to be compatible with Fausto Emulator MUST include cryptoworks Cardkey (06)
This keys used in internal by diablo cam emu
If the CardKey (06) not include you'll can't decode cryptoworks with Fausto Emulator
CardKey (06) added on Keys.bin has no effect under diablo cam emulator
*Include Betacrypt Tuneled Nagra 2 Providers
*Include ECM IV & ECM Seed keys under Irdeto2 Coding System
CS Cards Client supported:
CCCam (TCP)
Newcamd (TCP)
RadeGast (TCP)
Camd35 (UDP cs357x)
Camd35 (TCP cs378x)
Camd33 (TCP)
Gbox client (localhost only, default ports)
Twin Protocol (Serial)
CS Cards server supported:
Newcamd (TCP) & EMM Support
RadeGast (TCP)
Camd35 (UDP cs357x)
Camd35 (TCP cs378x)
Camd33 (TCP)
Support:
- Ethernet (linux box, diablo wifi,...)
- SSSP/HSIC/TM Share/CSC (Serial)
- Season Interface (Cams/box Readers)
- Diablo Wireless (base unit)
Main Functions:
- Emulator
- Logger
- Net client
- Card server
- Cards support
- DVB Plugins (without pctv card)
Version 1.43 (15/03/2010)
- Editor
Modele.xml modified
- Emulator
*Settings files:
FeSettings.ini modified com parameters about season removed
Season.ini added com paremeters for each emulation (Irdeto,Seca,Viaccess,Cryptoworks,Conax)
To keep compatibilities with previous version FE use default settings
Report To Fausto & Season INI File.txt for more details
To create default settings file delete existing one, open emulator window and the new one will be created
*Serial:
- Added CSC ECM protocol support, 6 versions (Now avalaible SSSP/HSIC/TM Share/CSC ECM)
Tested with version:
* Titanium /technocam
* Tiger t6
* Starsat
* Dreamsky
* GlobalStar
* Technosat
Added settings file for named CSC_Cas_Datas.cfg (folder ..\Fausto\Serial\)
Settings file can be edited via tab SETUP
Choose CSC_Cas_Datas.cfg on file list
Press OPEN
Made changes
Press SAVE
Usefull only if ECM not comes from box, it others case NOT required
*Server:
Newcamd: Irdeto EMM code improved
Log File: can be produced without ECM Debug ON
*Client:
-Added possibility to set Connection Max delay
Report to file FaustoClients Example.cfg dor syntax & example (Folder Fausto\Emu\CardClient)
-Added Twin protocol
For client definition report to FaustoClients Example.cfg on folder \Fausto\Emu\CardClient
For more informations read file Fausto & Card Client.txt
Joined file twin_cache.cfg (Folder Fausto\Emu\CardClient) with somes channels example, add your own
-CCcam:
Accruate compatibilities with Nagra3 provider (specially with card read by Newcs)
Added default provider zeroed when only caid defined for a card
-Log File: can be produced without ECM Debug ON
*Cards:
TNTSat Default AES key added if not set on Cards.ini file
Sky Ita card fix
*Setup:
Added posibilities to edit file
CSC_Cas_Datas.cfg
twin_cache.cfg
Include syntax definition
*Language file:
Added [Strings] datas
Added Russian language file thanks to the author
Enjoy.
Try this link for further detail:
PHP Code:-http://www.dreamboxfile.com/DM500/Utilites/Fausto-v1-43.html -
see this thread below bit old but all info there
