port forwarding
  • thered
    • 4915
    port forwarding
    i have just tried to assign myself a dynamic ip and port forward my router to my dreambox unfortunately i am not sure if this has been done correctly
    is there a simple procedure that will let me check if this is working correctly as i am unsure if it will work
  • satman
    • 736
    Try access same port from outside your network,, or ask someone on here you trust in pm or summit to check,,,
    no good checking from inside LAN or it will always show.
    P.s this wont work for web-x-tv
    boom!
    • thered
      • 4915
      thanks will you have a go if i pm you
      do you just need the blah blah dynds and the ip of the dreambox or is there anything else thanks
      • Curious123
        • 2591
        The simple procedure is to type in the url you have assigned yourself into your web browser than waiting to see if it goes to your dreambox.
        • thered
          • 4915
          right my dynamic ip must be working fine curious because i done as you suggested and it came up with my router
          only problem is the link you provided me to portforward does no have my router on so i tried it manually through the router menu it doesnt seem to have worked
          so i need to find out how to configure my router
          • Curious123
            • 2591
            What router make & model have you got?
            • thered
              • 4915
              this is my router apologies for the slowness of my replies but my interwebs on go slow
              TL-WR841N
              i have changed my settings again now when i type thered******** into my search bar i get the password settings for my router do you get the same
              • Curious123
                • 2591
                I am not getting your dreambox but that could be my end due to a few problems I am having with my router. I pinged your url and got a reply back so you are probably good to go m8.
                • thered
                  • 4915
                  probably eh famous last words
                  thanks for your help m8 so now if i want to join a server do i basically need to insert a ccam config file which they supply to my box then im all ready to roll or is there more
                  • Curious123
                    • 2591
                    When you install CCcam 2.0.10 onto your dreambox it will also put file called CCcam.cfg, this the config file for cardsharing with CCcam 2.0.10. In here you need to insert the F line which create and the c-line which you recieve from the cardsharer in exchange for your c-line. Basically you need to write an F line and C line for yourself and you are ready to roll.
                    • LENNY1
                      • Oct 2008
                      • 41
                      hi dont know if its any help but if you go in to router menu application & gaming you can set port forwarding etc there
                      • thered
                        • 4915
                        would this be a c line?
                        c:thereddoesnt.exist.com 12000 thered**** *******u
                        and what is the 12000 for?
                        also would this be the f line
                        f: thered**** *******u
                        so i put the f line into mine and send the c to whoever and thats it?
                        or is this all wrong?
                        and if its right its assuming my port is forwarded correctly or im goosed
                        here's another thing ive just thought the password in the lines above are there for my router my dreambox or the dynamic ip at dyndns
                        • Curious123
                          • 2591
                          The 12000 is the port you have opened to allow cardsharing to come through your router to your dreambox. I have pasted the explaination by nut which will help you create your f&c line
                          'you make an F:line with what you give your share e.g
                          i take it you have set up a dns server?
                          you send your m8/share your C:line like this
                          C: foxyWL.no-ip.com 12000 (username)nut (password) kaos
                          without the text in ( ) ( ) so that leaves nut and kaos
                          like this>
                          C: foxy.no-ip.com 12000 nut kaos
                          you would make your F:line as folows
                          F: nut kaos
                          do you see what happening? the user name and password i give in my C:line to you i use as my F:line think of how you log in to this forum? if you dont have the right name and password you aint coming in! the user name and password is the key to the front door ill send you the key in the C:line and let the F:line (lock) let you in.'
                          • Fano
                            • 331
                            If one is only connecting to an external card server and not sharing themselves (i.e C line only) am I correct in saying that you dont need to open ports ?
                            • thered
                              • 4915
                              like this>
                              F: nut kaos
                              thats where i nicked it from i was wondering what the 12000 was so mine if it is working properly will be 53 instead i think as this was the port my router opened automatically when i entered my dreambox ip into the router configuration
                              i have a funny feeling that my port forwarding doesnt work though and in where i insert the username and passwords as in the post above which passwords is needed is it router dreambox or the dyndns password i used when i opened the account
                              my head hurts
                              i would be interested to know if fano's point is relevant too as my aim is to join a server not to buy a card and share it so if his point is valid and it seems too make sense whether or not my port is correctly forwarded is irrelevant
