dreamup?
  • harrys
    • Aug 2009
    dreamup?
    tried to connect my dreambox up to dreamup im using a null lead but no response from dreamup. im only connecting when ive started the dreambox up when ive clicked connect. what other prog will let me put an image on.
    read the stickies at the top of dreambox section on using dreamup it will tell ya how to do it step by step
    dont expect to be just spoon fed everything in your own post a little reading an yal be flyin it
    also your first post should be in the intro section not here
    • harrys
      • Aug 2009
      thanks for reply but ive tried every thing i can find in that section even more types of dream up.
      • dave-h
        • Apr 2010
        • 659
        Daithi mean't the red 'stickies' at the very top of this page...
        • baluba
          Which version of dreamup do you use? And which db are you trying to flash?
          • piopat
            • 708
            as baluba says which version of dreamup are you using and which version of dreambox do have ,are you using a usb to serial adaptor with the null modem cable .if your using an adaptor have you installed a driver for it (a driver is a bit of software that may come on a disk with the adaptor or you download it and simply put it helps the computer to see the box so it can be flashed) if your pc runs on vista it can be problematic with drivers. if your box is a dm500 i would say use an older version of dreamup (have a look in the links in my signature area) in my experience if the version of dreamup was the issue it would give an error message like flash failed aborted by user ,if you click connect and nothing happens its usually either the wrong com port and most often the driver as i mentioned above .
