B16MCC sky uk bouquets updated often
  • britneyspeers
    • Nov 2010
    Thanks for the updated bouquet
    • maney266
      • Sep 2009
      • 44
      #62
      needs a new bouquet sky 2 3 and some other channels arent working
      • markymids
        #63
        Originally posted by RuberDuck
        while this is not a official release by B16MCC it was generated by me a few minutes ago using the B16MCC front end software version 0.3.1. and all rights naturally go to B16MCC as it was his software that made this possible.
        the services database has been updated with all frequency changes made on 28.2 within the last few days. so this bouquet will be as upto date as it is possible to be.
        i am not at home so i can not test these but i post them here for you to test them and report back.
        i cant post the software used to generate these here as B16 has asked that it stay on his forum because it's still in beta but your more than welcome to get a copy from there if you want it.
        Are you allowed to say where the forum is?
        • RuberDuck
          • 1724
          #64
          dreamboxuk dot com
          • nassa
            • Dec 2010
            #65
            Its a very good software, b16 dreambox frontend database
            • RuberDuck
              • 1724
              #66
              yes i agree i'm a moderator over there albeit by a different name
              • heyapple
                • Dec 2010
                Seems all good so far
                • trance
                  • Aug 2009
                  • 223
                  #68
                  b16mcc is the man, this makes life a whole lot easier
                  • NaNaNiii
                    • Dec 2010
                    • 167
                    #69
                    Some channels appear grey when in the bouquet and dont work. This includes sky 2, 3 and most of the HD channels. Anyways to fix this? Thanks
                    • dej4y
                      • Dec 2010
                      #70
                      will this fix sid errors ? or do i need a new satelite.xml
                      • NaNaNiii
                        • Dec 2010
                        • 167
                        #71
                        Another thing. I've FTP'ed the bouquets back and fourth several times flawlessly. However, now, i can't FTP the files back to the box. Here's the log of when i try:
                        Connecting to 192.168.2.2.
                        Connected.
                        Dreambox response: Login successful.
                        ** Getting directory list /etc/enigma2/* **
                        Starting FTP transfer
                        Transfer complete
                        ** Sending file "/etc/enigma2/lamedb" **
                        Transfer aborted
                        Error sending file "lamedb" to the Dreambox.
                        Disconnecting.
                        Disconnected.
                        I don't know why did is happening. Any ideas. I've made sure that NewEnigma 2 settings are selected in Dreambox Edit
                        • cmartin198
                          • Feb 2011
                          fab
                          im new to this but these look wicked def worth a go cheers
                          • martinregan
                            • Dec 2011
                            #73
                            Dreambox 500
                            Newbie. Is there a StepByStep Guide anywhere for setting up all channels Bouquets etc
                            • akbarirfan
                              • Sep 2009
                              • 93
                              #74
