Hi I am getting really slow internet will this effect my cardsharing Eg. will the channels lag or not work at all.
Slow internet effects cs
Slow internet will affect your viewing quality
The panel has quite simply found 'no evidence' in support of allegations of 'exceptional levels of drunkenness, ticketlessness or violence among Liverpool fans' and 'no evidence that fans had conspired to arrive late at the stadium' and 'no evidence that they stole from the dead and dying'. -
As bd says slow internet can affect your quality , this said cs does not need huge amounts of bandwidth, i know some 1 using a dongle in lets say a very remote area who gets a decent pic.
If your using a pay server for a certain provider more than likely its over subscribed, as most of these are greedy f**kers.
@manxComment
Measurements For just the connection to Peers (Without viewing anything ) show that 60.4bits/s are sent to the server and 23.2bits/s received from the server every hour per user checking connection Peer to Client.
When connected to a Peer it works out like this
1 C line takes 5 x 16 x 8 = 200 bits/s
7 C lines would need 7 x 200 = 1.4 Kb/s
Each exchanged key = 16 bytes
So you view a Encrypted channel for 1 hour, if the key is updated every 5 seconds, (Sky Uk Approximate Card Refresh Rate) thats 12 exchanges / minute => 11520 bytes transferred to send or receive the keys (that is 0.01 Megabytes) ...which is nothing at all
Most IP receivers can even and with ease share on old Analogue Modems, so even to most basic Internet package which I think would be around 2meg would be more than fast enough to share with easy up to 30 peers.
Hope it help some of you calculate your own usage.Last edited by alunfennell; 3 October, 2010, 03:46.Comment
thanks for the info, was searching the internet for it.Measurements For just the connection to Peers (Without viewing anything ) show that 60.4bits/s are sent to the server and 23.2bits/s received from the server every hour per user checking connection Peer to Client.
Hope it help some of you calculate your own usage.Comment
