upc direct 1west signal probs
  • Wingnut
    • 376
    hi,just found out there that upc direct leaving some sats and all moving to 1west sat, unfortunatly i have a block of flats in that direction,now i can get quite a few channels on that sat even get a pretty good signal on Thor-5 @ 0.8 west 12341 28000 Duna 1HD MPEG-4 ,which i believe is the strongest transporter,is there anything other i can do to try get signal on upc direct,(im not demolishing the flats ? its just says tune failed
  • Wingnut
    • 376
    forgot to mention,is it not strange that when i do a scan on that sat i can pick all them channels up(upc direct) but when trying to view them getting tune failed,
    • Wingnut
      • 376
      been reading about the net etc and seems alot of people have experienced tune failed but not really able to answer why,i dont even thik the flats are now really bocking me as i seem to pick hell of alot of channels still.one guy has said he fixed his problem
      The solution is to buy/use a ALPS LNB. The fact is that some channels need more power. (its an 22Khz high band issue)
      can someone tell me if they think this wud work
      (iv noticed i can view some channles on upc direct but not all,)someone must no here,thanks
      • satsdat
        • Aug 2009
        • 75
        Do you have geniune dm?apparently tune failed is a flaw on the tuner side.i think the only way to solve is buy a new tuner
        • alliv
          • 299
          is upc not a cable company?
          is it a bird?......is it a plane?.....NO ITS MY CHEAP CLONE FROM CHINA GOING OUT THE ~~~~ING WINDOW.
          • Wingnut
            • 376
            I have gemini installed,its also a clone dm800s,didn't think it wud be an image problem or tuner problem as can clear most other channels ok and all other sats fine including hd channels,prob just upc direct on 1 west
