DreamBoxEdit-IHAD Edition 4.0.0.0
  • dave-h
    • Apr 2010
    • 659
    New in 4.0.0.0
    - code migration to Delphi 2007, for later unicode support
    - removed XP visual styles (there were some problems after migration to Delphi 2007)
    - added theming for some components
    - added channel numbers in bouquet panel
    - added new hints in main list and bouquet details, now with picon and service reference
    - added option to assign and remove picons
    - added cleanup function for local picon directory (which removes all unused picons) to tools menu
    - added option for automatic picon upload to FTP window (Note: unzip command on your dreambox is required)
    - added configurable per profile picon path to options panel
    - added quick profile selection in statusbar
    - added enhanced filter expressions (SQL style):
      use % as substitute for zero or more characters (e.g. %sky% shows all channels with "sky" in name),
      use _ as substitute for exactly one character (e.g. _sky_ in package filter shows channels of provider "BSkyB")
      use \ as escape character (e.g. %\%% shows all channels with "%" in name)
      if you don't use above filter characters the filters will only show exact matches
    - changed TV service types defaults (now including HDTV service types)
    - fixed error message when saving alternatives bouquet with parental lock
    - fixed error message after reading radio service alternatives
    - fixed bouquet change is now disabled while picons are loading to prevent errors
    - fixed alternative service names are now written in UTF-8 instead of ANSI
    - fixed alternatives are now deleted if service is removed from main service list
    - fixed alternatives are now handled for each user bouquet seperately
    - fixed translation problem in alternatives panel
    - fixed problem with incorrect filename if you tried to add alternatives for a data service, adding alternatives
      for data channels is not allowed, please set proper service types in advanced options first
    - fixed keep filters when adding alternatives for a service
    - fixed missing picons when using cut&paste or drag&drop
    - fixed display of proper bouquet name when bouquet has been renamed
    - fixed display of picons when adding services to an empty bouquet
    - removed "input selection" in main service list as it didn't work as expected
    Digital Kaos - Downloads - DreamBoxEdit-IHAD Edition 4.0.0.0
