tuner problem or cable problem ?
  • pob639
    • Feb 2008
    • 224
    Yesterday all my channels and dish stoped moving :-( now i also get snr 46% ish and no agc ??
    What i've done
    1: checked cable are clear (no direct shorts but 300ohms resistance )
    2:checked voltage out of tuner 18v and 13 v (correct i presume )
    3: checked voltage at end of cable run by vbox only getting 10v and 13v ???? (fishy)
    4:checked at end of run by lnb 10v 13vthere also ?
    What do you guy think is it water in the coax or a tuner problem the system has been up running well over 4 years no problems until now grrr
    dont want to reflash image got everything up n running as i want epg vod streaming
  • cactikid
    • 12017
    has dish moved as signal looks very low thought it should be in the 85+
    • pob639
      • Feb 2008
      • 224
      Replaced cable to vbox2 everything sorted now must have been water / ice something in cable but strange that it wasn't down between screen and main core just a little bit high resistance ???
      I was using crimped f-type fittings no breaks in cable or joins with insulation in good shape !!
      Snr and agc back up into the 90's :-)
      dam cables hay
