Alternative GEMINI addon servers
  • MrEee
    • May 2011
    Did anyone test this with Gemini iCVS for 500HD and if so, did it work?
    • djmuki
      • May 2011
      thx for this
      Originally posted by Flashing-Dude
      Everybody knows that the IHAD 22.01.2011. The ability to shut down direct download from a server in Gemini DreamBox receivers. Manually inserting the DreamBox can be hard (if it brings in more receivers simultaneously) as well as changing file permissions and so far it was all automatic odradjivano direct download. E and it has come to an end with the alternative URLs for download CAMs from different servers.
      The working principle is very simple and below the URLs entered in the path var / tuxbox / config / useraddon.xml that you previously copy to the HDD from the computer (I suggest the simplest FillaZilla Client FTP manager) and the same open with Notepad + + or Wordpad and copy / paste URLs.
      Upon completion and save the file back to the same location in the Dreambox and that the var / tuxbox / config /.
      Added alternate servers is located on my servers to download them arriving by clicking on the blue button on the remote -> Addons (option 2) -> OK
      These servers are included...:
      <item name="Dream Devils Server" url="http://www.moonbeamonline.com/dd/addon_server/ddserver.xml"/>
      <item name="HackSat Addons 1" url="http://www.dvbfiles.com/camd/cam40.xml"/>
      <item name="HackSat Addons 2" url="http://www.uydu.ws/camd/cam40.xml"/>
      <item name="Luxsat 4.0" url="http://www.luxsat.eu/hpengine/download_files/luxsatcam4.xml"/>
      <item name="Imajteam-Server" url="http://www.forumimaj.com/dreambox/addons.xml"/>
      <item name="Gold Panel" url="http://www.turkdvb.com/dreambox/server.xml"/>
      <item name="Sat-4-All" url="http://www.sat-4-all.com/portal/plugins/addons.xml"/>
      <item name="ID-Server" url="http://members.vol.at/easynet/gemini_server.xml"/>
      Found this laying around ..... use at your own risk, but should be legit...... ( haven't personally tested as i don't use GEMINI )
      Please reply with info about if it's working or not working....
      • niko70
        • Jun 2011
        hi.are these links alternative for cam and cam conf ?
        • chikki
          • Jun 2011
          • 5
          #34
          hi all
          im new to db....plese tell me
          how to use these on dm500s?
          • chikki
            • Jun 2011
            • 5
            #35
            im not able to connect to any servers... i have two showing on ccc info
            • domirudi
              • 104
              #36
              what kind of image do you recomend?
              • deffc0n
                • Aug 2009
                • 894
                #37
                New link here:
                • wizard3110
                  • Aug 2011
                  Can anyone confirm if this works in GP2
                  • jarodu
                    • Aug 2011
                    Are these Servers still active?
                    • espenepos
                      • Aug 2011
                      Thanx for detailed and very helpful description of how to expand addon-serverlist. :-)
                      It worked perfect for my GP4.70, even if some of the servers in the initial list are now in-operative... Thanx again! :-)
                      • gievski
                        I tried to download cccam from gemini server like i did a year ago but now it seems to be deleted. Does anyone know why, or maybe where can i find cccam 221 ?
                        • XStoneX
                          • Aug 2011
                          #42
                          Is it possible, that the correct directory is now /etc? Only there I can find the file useraddon.xml. I own a DM800 (E2) with Gemini 5.1. If I put the downloaded file into this directory, there are no more servers than the original Gemini Download Server choosable in the Blue Panel.
                          Have you got any ideas?
                          Thx & Greetz,
                          XStoneX
                          • yahia abu lafah
                            • Aug 2011
                            does it work with dm 7000
                            • pappas11
                              • Sep 2011
                              at gemini 4.2 where i can find useraddon.xml ?
                              • Jo-Jo
                                • 511
                                #45
                                var/tuxbox/config
                                i have just replaced my useraddon.xml file with the one posted in the first post and some work and some don't but from the ones that do work you can get most cams etc that are missing from the gemini servers
