Cccam startup
  • eidur
    • Dec 2010
    Cccam startup
    Is thera a way to have your reciver start up on Cccam?
    That is to say if the power is turned off the reciver automaticly starts up with Cccam when the power comes back on?
    Eidur
  • springer
    • 12
    Restarting from main menu should do the trick
    • Jo-Jo
      • 511
      Yes make sure cam is running then Goto menu/shutdown/restate enigma
      • eidur
        • Dec 2010
        it works
        Eidur
        • karlpowell
          • 189
          OR telnet to the box and run from command window like this.
          start - run type cmd (press enter)
          in black window type telnet and your box IP IE telnet 192.168.0.1
          you will need to install telnet client if you use vista or win7.
          enter root as user and your password ( default = dreambox)
          type all this
          cd ..
          cd ..
          cd usr (enigma2) or cd var (enigam 1 )
          cd bin
          now to see if ccam is running already type ps, if you see ccam in the list kill it by typing kill and the number besides ccam.
          next type
          ./CCcam_2.2.1 -dv ( for ccam 221)
          ./CCcam_214 -dv (for CCam 214)
          and you will see cccam run and will ouput to the command window .
          have fun
          • monkey666
            • Sep 2012
            • 4
            Awesome thank you ! it kept booting into common interface for before was a nightmare your answer solved the problem thank you.
