Catseye Enigma 2 Settings
  • saj1985
    • 785
    #76
    Originally posted by catseye
    Catseye E2 Settings File 75 East-58 West 10.12.2011
    Includes most recent updates from KOS & more...
    16 East
    Changes to Digital ALB Package
    7 West
    Packages returned to favourites section are now in alphabetical order for ease of use & location
    Yahsat 52.5
    This sat has been added to the list
    Plus many more...
    Enjoy
    hey mate, just wanted to say thanks for your hard work,
    its very much appreciated!
    Dreambox 800hd se/Dreambox 500s, 90cm Solid Dish, Tm2600 Motor, TM-1 Gold LNB!
    • kaisar1
      • Aug 2009
      • 462
      #77
      hey catseye. i tried using dreamset but im having difficulty using the software. when i select open and try to load you bouquets, theres loads of files. which one do i select. theres a file called "lamedb". dont know what to do, any help anybody?
      • kaisar1
        • Aug 2009
        • 462
        #78
        i can send the files over via dreamboxedit, but bouquet does not load properly. for example in the favourite section normally it should be split up into different genres e.g entertainment, sports however when i transfer the files in the favorite section i get loads of <n/a>.
        why is this, any help?
        • catseye
          • 388
          #79
          Yes m8 select the lamedb file-make sure under the 'set up' tab its set for enigma 2
          Whilst its transfering you should a little image on your pc screen of files transfering from pc to sat box
          if you see the channel lists on screen & its 'greyed out' it means your satellite configuration isnt set up own your sat box
          Just make sure all the sats you want to view are set to the same lnb
          select the favourite section of the settings using blue button on box remote to navigate around
          enjoy
          Vu Duo & Channel Master 1.2 meter dish located in middle england
          • kaisar1
            • Aug 2009
            • 462
            #80
            I still can't get it to work properly. Alot of <n/a>. I'll record a video to show what I'm doing and put it on YouTube.
            Is it possible to download your bouquet directly through the dreambox via TS panel. If so how???????????
            I got pheonix edition 1.33 2.1 sim botloader 82 software.
            Sent from my HTC Desire using Tapatalk
            • catseye
              • 388
              #81
              If you use blackhole image you can download latest version via their downloads panel
              • catseye
                • 388
                #82
                Whar receiver are you using?
                • kaisar1
                  • Aug 2009
                  • 462
                  #83
                  Dm800 HD pro sim 2.1 bootloader 82. Where can I download it from direct through box??????
                  • catseye
                    • 388
                    #84
                    Using dreamset v2.34 software
                    Click on set up tab, then connection
                    Configuration -type in your box name
                    Box Ip= IP of your sat box
                    User name =root
                    Passsword= what ever you choose
                    firmware=enigma2 version 4
                    Save configuration then ok
                    Open up unzipped file so its showing settings on your pc screen
                    Click transfer -at top of mini screen that appears it should have your box name & its ip address
                    Click write
                    You should see image of file transfeing to box
                    followed by complete message
                    Try rebooting gui on box & follow previous posts if channels are greyed out
                    It might be worth your while if this fails to check your firewall is blocking it
                    • 00360362878
                      • Mar 2010
                      • 488
                      #85
                      16 East
                      7 West
                      Yahsat 52.5
                      Plus many more...
                      Enjoy
                      54 veiws with a handful of thanks. No wonder you guy's get hacked off.
                      Thanks catseye
                      • kaisar1
                        • Aug 2009
                        • 462
                        #86
                        I downloaded one of your bouquets direct through the TS panel. Thanks
                        • catseye
                          • 388
                          #87
                          Catseye Enigma2 Settings File 75 East-58 West 24.12.2011
                          Includes most recent updates from KOS site & more..
                          Enjoy & Merry Christmas
                          • masacist
                            • Dec 2011
                            #88
                            Merry Christmas to you too!
                            I seem to have some problems with CrossEPG downloader not updating the information for the channels, in other words i cannot scroll through the channels once i've installed the Catseye listings and downloaded with CrossEPG, the channels just show as blank. Is there another downloader or does anyone have any settings i could use for 28.2e and 13.0 please?
                            Feel free to move this post if its not in the appropriate place too
                            • andy91
                              • Aug 2010
                              • 3583
                              #89
                              Are you using Dreamboxedit to add Catseyes bouquets?
                              Is this on a Dreambox 800hd
                              Do you mean showing the channels in epg?
                              Andy.
                              • masacist
                                • Dec 2011
                                #90
                                Ah sorry, forgot to mention its a Qbox HD mini i'm using, however i was searching for this bouquet and couldn't find the relevant Qbox section
