Catseye Enigma 2 Settings
  • darren221980
    • 25
    #271
    Is anyone else having an problems with the latest catseye bouquets? I've put them onto two DM800's so far and on both this causes the channels to be come greyed out and now i have no tuner configuration apparently whereas prior to uploading the bouquets i did have the tuner configuration.
    • catseye
      • 388
      #272
      Catseye E2 Settings File 75 East-45 West 01.06.2013
      Enjoy
      Updated & amended file added at 15.13 today
      Vu Duo & Channel Master 1.2 meter dish located in middle england
      • darren221980
        • 25
        #273
        Enjoy
        Thanks Catseye, this one has fixed it for me.
        • ndiqbal
          • 10
          #274
          Thanks Catseye
          Only issue is that Im on Dm800HD Sim2.01 - Yr listing Crash, freeze the box - Is there something different you have done? 75E 45W
          • Mickouse
            • Aug 2010
            • 4
            #275
            Thanks for your job
            I don't know what's happened but it seemed to reduce my snr since i've put this list, what do you think about it? my snr lever is not stable it can't stop moving down or up and of course it's freezing....
            • catseye
              • 388
              #276
              Catseye Enigma 2 Settings (ALL FILES) 14.06.2013
              Includes most recent updates from usual locations, KOS, Lyngsat & many more...
              Enjoy
              • catseye
                • 388
                #277
                Enjoy
                & Here is the 6th File
                • darren221980
                  • 25
                  #278
                  I've just downloaded and sent this to my DM800, however after a reboot the tuner configuration has just vanished
                  Is there something wrong with the bouquet?
                  Edit... I've fixed it, looks like the satellites.xml file was at fault on my box after uploading this bouquet. I've now replaced it with a working one and bouquets are now working fine
                  • skybot1
                    • Apr 2013
                    • 21
                    #279
                    ok the way i have fixed mine is update the satellites.xml file too
                    heres the one i have just updated and ftp to my box and do a full reboot
                    works 100% for me
                    regards
                    skybot1
                    • skybot1
                      • Apr 2013
                      • 21
                      #280
                      also like to say that catseyes settings are the best i have ever used , i always use them, the lay out is the best for my box,
                      thanks for your work !!
                      regards.
                      • M4NIK
                        • 91
                        #281
                        hi having a problem getting favourites working on full motor ts-image 3.0 on dm800hdse
                        • beats2006
                          • 198
                          #282
                          Latest update removed my tuner settings completely also tried a new satellite xml file but didn't work ended up having to reflash the box
                          • sexysam
                            • Oct 2008
                            • 209
                            #283
                            Latest 75-45 updates removed my tuner settings as well.Spo hard to load some one else.First time its happen to me as I always use Catseye
                            • beats2006
                              • 198
                              #284
                              If you download the satellite XML file in the post above and stick it in the catseye folder replacing the one already there then load the bouquet it works fine.
                              I had tried loading the XML file to the box after and it hasn't worked.
                              • catseye
                                • 388
                                #285
                                Catseye Enigma 2 Settings (ALL FILES) 23.06.2013
                                Includes most recent updates from usual places
                                Tested & working fine at present on vu duo receiver
                                Enjoy
