incompatable SKIN
  • h1_to_1
    • Aug 2009
    • 22
    incompatable SKIN
    I've just installed an incompatable skin and now stuck in a reboot cycle, can anyone help?
  • freck
    • 1076
    Reflash it... serial cable jobby
    Freck
    • h1_to_1
      • Aug 2009
      • 22
      Thanks reflahing now, what a pain
      • Rodbouy
        • Jul 2010
        • 1320
        When the box boots, you have enough time to log in via dcc and remove the skin, this will restore it back to default skin saving you to re flash.
        /usr/share/enigma2
        • toysoft
          • 752
          Do as Rodbouy tells, remove the folder of the skin on /usr/share/enigma2, it will then use the default skin.
          TS
          • griff
            • Mar 2009
            • 343
            Just done this and thought I had 2 re flash ideal will give it a go thanks
            • griff
              • Mar 2009
              • 343
              Just done it and worked like a dream. Saved a lot of flashing
              Thanks griff
              • RuberDuck
                • 1724
                it's only the enigma 2 GUI that is in a bootloop so when ever you box goes into a loop you have all the time in the world to login with either a FTP connection or start a TELNET session.
