Dreambox auto update?
  • suley
    • Aug 2010
    • 49
    Hey Guys, i have a DM800HD and have been using it for a while and its great. The only problem is every so often the frequencys update and so i have blank channels or need to update. Till now i have been using SGTFlipFlop SKYUK Bouquets however it takes me about and hour or so to update it since i have channels in a certain order and unless its this way family keep annoying me about it. I was wondering is there any way to update the channels list or frequencys to either auto update via ascript or plugin or to compare sgt flipflops list to my own custom positions and apply? Any ideas or suggestions?
    Suley
  • DMBoot
    • Nov 2011
    • 114
    Suley
    Is this a plug-in to auto update?
    You're still going to have to do the work of re-arranging things though.
    • delly007
      • May 2011
      • 54
      Suley
      hi u can use SGTFlipFlop new list to ad the new channels
      just open dreamboxedit and open the new list.
      then open dreamboxedit again with your list.
      then all you have to do is delete the ones that are not working on your list
      then on the new list right click on the channels that are new and copy the new ones. and go to your list and paste them in your list where u had them. then save and flip to your box.
      • stanman
        • 4
        There is a new online auto bouquet plugin developed by Lraiser, it pulls the info from the sat and configures the bouquet exactly like Sly, though placeholders still needed.
        I have used this file on a TM800 and it worked a treat and using it on a ET9 as well as Ultimo.
        Have to say probably the best plugin I have seen in a while
        • lfc84
          • Aug 2008
          • 67
          enigma 1 would be fantastic...
          • uu161
            • May 2012
            • 372
            Guide:Auto Update Channel List/Bouquets..
            if you like the post use the Like button located bottom right corner of each post
            if you wish to thanks kindly use the thanks button located bottom left corner of each post instead making a post for thanks
