AutoBouquets E2 28.2E plug-in
  • macbow
    • Oct 2010
    • 15
    #46
    can you suggest an image for me, kernel needs to be 1.6, so i can install tspanel onto my box, thx in advance. mac
    • lincsat
      • 1228
      #47
      Go for a more recent Blackhole, the V133 Phoenix edition is popular. There is a Patched V166 but that is quite big as well.
      • a8ree
        • Nov 2010
        • 31
        #48
        I am trying to install this on my image
        When trying to browse the local storage (HD&Flash) I get
        "no displayable files on this medium found!"
        Anyone got a solution?
        • Hokane3
          • Sep 2012
          • 17
          #49
          VU + Duo
          does anyone know why the lcd display at the front of box is blank except for tiny green light at the top left of the display.
          Is is a PSU issue or is the cable not in fully.
          Would appreciate reply
          • cbbella
            • 22
            #50
            if your using a dreambox try putting it in the root of the dreambox and not the temp folder. you should be able to see it then. it worked for me
            DM800HD PVR clone
            90cm dish - motorised
            • a8ree
              • Nov 2010
              • 31
              #51
              Thanks, shall try that tonight....mines a DM800
              • ratman
                • Feb 2011
                • 27
                #52
                Awesome plugin really helped me thanks guys
                • a8ree
                  • Nov 2010
                  • 31
                  #53
                  Magic! That did the trick
                  • Huds78
                    • Nov 2012
                    #54
                    I just took the plunge and installed it on my Dreambox and glad I did, I used the dreambox control centre and put it across using ipkg packages under Tools. It took around 40 mins to setup but now it has I`ve deleted the sgtflipflop one and will just use this.
                    • gazza341
                      • 5
                      #55
                      looking forward to having a dabble with this autoboquet plug-in. just posting in this thread as advised when i try to d/l it says not enough permissions
                      • Tony Mc
                        • Apr 2010
                        • 13
                        #56
                        Where wouldI find the root folder on my 800 hd
                        • andyfinn
                          • Nov 2012
                          does it delete existing files
                          • cbbella
                            • 22
                            #58
                            when you connect to your dreambox via ftp you will see lots of folders with different names like dev, media, var,tmp, etc. that is the root. just transfer it there so you can see it alongside all these folders. what i mean is do not put it inside one of these folders because it would then be in the folder and not in the root if you know what i mean
                            DM800HD PVR clone
                            • neil0129
                              • 50
                              #59
                              hi, been using this plugin on my DM800 for the last couple of weeks, all working great.
                              But i dont like the placeholders, i understand on an OpenPli image these placeholders can be skipped. is OpenPli the only image this works on OR can i "skip" on other images too?
                              • markshore
                                • Oct 2010
                                • 120
                                #60
                                Hi installed last night looks good now only the picons to update, if a channel changes frequency just change the .png to the correct title and send to the box job done. Maybe a bit harder for new channels but sure that will be posted on this forum.
