AutoBouquets E2 28.2E plug-in
  • frank087234
    • Jul 2012
    • 61
    #106
    Originally posted by smirnoff_rules
    latest one here
    here is latest AutoBouquets E2 plugin for testing.
    9-10-2012
    now also detects and parses the hidden data channel names.
    add autobouquets selection menu to service searching menu.
    also adds the channel epg numbers to the official bouquet.
    some other potential bug fixes.
    thanx to LraiZer
    what is debian folder for???
    • scoopster123
      • Aug 2012
      • 5
      #107
      many thanks for this
      • Aindriu
        • Jan 2013
        • 7
        #108
        Originally posted by daddydeadlift
        yes they include setanta and rte
        What about the satellite though? We point to 19.2E here not 28.2E.
        • tipster69
          • 91
          #109
          I tried this earlier today for the first time.
          It installed straightforward enough, and the front end works fine. However, when I went to start the scan, it gave me the following error "wget: cannot connect to remote host (127.0.0.1): connection refused".
          I know it must be something obvious but I am not clued up enough to find the issue myself.
          ANY help much appreciated.
          CHEERS
          • tipster69
            • 91
            #110
            Hi, can anyone help out with the above issue. I would really like to get this working if at all possible.
            Thanks.
            • deadbeef
              • Jan 2013
              • 5
              #111
              i looks like you would be required to use the files in the debian folder if you were creating a new .ipk installer with any modifications to the plugin so that the original author's maintainer details are in the new installer package that you created.
              Originally posted by tipster69
              CHEERS
              maybe you disabled the web interface in the settings somewhere or you have removed an OpenWebif plugin? you may have either no webif installed or you may even have two different webif installed, a built in one and a self installed OpenWebif and both are enabled?
              • Aindriu
                • Jan 2013
                • 7
                #112
                An absolutely brilliant plugin!!!
                • msrie
                  • Oct 2011
                  #113
                  Yep class plugin, really works well, saves us from finding all the versions of local stations.
                  • tipster69
                    • 91
                    #114
                    I still haven't found a solution to this if anyone can help?
                    CHEERS
                    • deadbeef
                      • Jan 2013
                      • 5
                      #115
                      Try overwriting your \usr\lib\enigma2\python\Plugins\Extensions\AutoBou quets\autobouquets_e2.sh file with the one in this archive. This one may work for you because all the error checking code has been removed in this file. There are no guarantees on this working! This file should be a little faster than the file in the plugin.
                      • tipster69
                        • 91
                        #116
                        THANKS very much for taking the time to do the above for me. Your edit worked a treat. CHEERS
                        Great plugin by the way, thanks.
                        • PaphosAL
                          Old Git
                          • 1064
                          #117
                          @ deadbeef: I've sent you a PM
                          Cheers- AL
                          • PaphosAL
                            Old Git
                            • 1064
                            #118
                            Oops, sorry- I thought I heard a BUMP
                            • wisesmurf
                              • Feb 2013
                              Every time i try run autobouquets I get an error and the box resets..
                              • pointme
                                • Feb 2013
                                +1.
                                Thanks alot!
