AutoBouquets E2 28.2E plug-in
  • rizla13
    Hi guys
    Does this autoboquet work on the latest Black Hole 2.0.1 OE 2 image on a vu+ uno?
    It currently works on the blackhole 1.7.9 image
    • DMBoot
      • Nov 2011
      • 114
      #152
      Originally posted by 68tr
      This is just what I need to keep my system organized and up to date. Many thanks. Great post.
      LraiZer is the man to thank as he wrote the plug-in.
      I only posted it here.
      • austine65
        • Aug 2009
        • 30
        #153
        Hi everyone.
        Can somebody pls share/upload the current picons for E2 boxes?
        Thanks in advance.
        • dj235
          • Feb 2012
          Hi Thank you for the post, is this installed via the add on manager. Hope its not a silly question but I am new to deambox? Thanks
          • ferrariboy
            • Sep 2011
            #155
            I've downloaded this plug in, but it takes a long time to run, and doesnt change my channel order. Can anyone help? Should I delete my own bouquets first before scanning? Can someone help an idiot out please.
            • stelito
              • Apr 2013
              Hi guys, sorry to bother you with a stupid question. I'm new to all this & can't find Sky Box Office on my channel list. I have a VU+ Duo with Enigma2 and VIX software. Not sure how to set up Bouquets & I'm getting really frustrated with it all. Can someone offer some advice please?
              • lincsat
                • 1228
                #157
                If using the original plugin, then update to the March 2013 release, it's much faster. When done, try restarting Enigma to see the changes. The new Bouquets will be at the start of the list (Assuming you've told it to generate a default set), you can then delete the older bouquets.
                On BH, the Autobouquets generates a Sky Box Office bouquet, I would think it's the same on Vix.
                • mart16
                  • Aug 2011
                  • 9
                  #158
                  Fantastic results on a dm800hd, installed and scanned within 5 minutes. Kept my sgt flipflop bouquets but not really needed as these are in sly order. Thanks again.
                  • lombard
                    • Aug 2008
                    • 793
                    #159
                    Hi, i tried the enigma2-plugin-extensions-autobouquets-e2_201303010205_mipsel on dreamboxuk 2.1.2 on a DM800HD and it works fine and scans quick, only 1 issue when i click custom channel swap to yes, so i can get itv hd , channel 4 hd , channel 5 hd first, some reason the 101 - is BBC Alba ? even when i selected wmids hd ? when i turn off Custom Channel Swap . its correct bbc 1 wmids, but of course then dont get hd channels of itv , channel 4 and 5 ? anyone help ?
                    top plugin
                    • LraiZer
                      • 126
                      #160
                      local channels have moved positions since plugin release, edit your /usr/lib/enigma2/python/Plugins/Extensions/AutoBouquets/custom.txt file with a unix/linux compatible text editor to read:
                      101=141
                      102=142
                      103=178
                      104=230
                      105=171
                      • neil0129
                        • 50
                        #161
                        hi, been using this plugin it for months now, works great.
                        Just having 1 problem I hope someone can help me with. I have added some channels (mtv trax, irish ones) using the supplement file. This worked as expected, i added them to spare numbers 992-995.
                        I then wanted to swap these channels. I edited the custom text file, and for example added the line 168=992. But this did not work. The custom swap worked fine for channels 101-105, they swapped no problem, but none of the supplement added channels would move, they stayed in the 992-995 area.
                        What am i doing wrong?
                        • LraiZer
                          • 126
                          #162
                          you cannot swap channels with blank channel numbers using the custom.txt file.
                          you need to directly insert channels into blank positions 168, 169 using supplement.txt file.
                          supplement.txt ( 168 = 00a8, 169 = 00a9 ):
                          00a8:1255:01:2585:07fb:11a0000:BSkyB:NDS:TV3
                          00a9:4693:01:cb87:08fd:11a0000:BSkyB:NDS:3e
                          • neil0129
                            • 50
                            #163
                            ok thanks for the reply, but i thought i read somewhere that doing that would upset the sky epg numbers, that they all get shifted by one, so say sky sports 1 moves from 401 to 402, or is this not the case?
                            • lincsat
                              • 1228
                              #164
                              If you corrupt the database, just delete the bouquets and scan again - that usually fixes it.
                              • gingeee85
                                • Jan 2012
                                • 197
                                #165
                                ok so i have a brand new box, blackhole enigma 1.79. all i do is channel scan then install this addon in order for it to work? how do i ftp is there a set ip and password?
