I noticed people saying to change the permissions to 755 etc, i havent a clue how to do that? can somebody help with that? where is the option or notepad to change the permissions?
1) yes, the adult bouquet is disabled by default when you install the plugin. you need to enable the adult bouquet in the plugin options to create it.
2) yes, you can move bouquets and still retain the official channel zapping numbers. the following options are required to allow this.
Use HD First Bouquet = no
Make Default Bouquets = no
3) yes, set option Custom Channel Order = yes, and edit custom.txt file in AutoBouquets plugin folder. the example custom.txt file is already set to replace bbc1,itv1,channel4 as these are FTA channels. you will have to look to edit the custom.txt file to swap channel5 and any other channels.
where can i find this custom.txt file....where can i find the plug in folder?
The instructions for installing should already be known to every Enigma2 receiver owner if not i suggest you read some of the Guides in the Dreambox section, Also look at the second post of this very thread for how to install
Finally done after 45 minutes, but my old boutiques are still there, and the new ones there is a lot of gaps in between channels with nothing example 242 discovery shed, but then 243 244 245 are blank any ideas why?
And thats because it follows the $ly channel numbering sytem so after 242 next channel should be 246
Thanks for your reply is there a way is there a way to do it without getting gaps between the channels? Also how do I delete the old boutiques?
To remove the channel gaps you will have to alter the script that auto bouquets runs there is a giude or a post somewhere on the forum that explains this, As for the bouquets maybe delete everything first and then start a fresh
