AutoBouquets E2 28.2E plug-in
  • lincsat
    • 1228
    #211
    Originally posted by MW35
    Finally done after 45 minutes, but my old boutiques are still there, and the new ones there is a lot of gaps in between channels with nothing example 242 discovery shed, but then 243 244 245 are blank any ideas why?
    If you are using the March 2003 release, then it should be done in around a minute, I guess that you are using an old version.
    If you just want Sky UK bouquets, then delete all the bouquets from the box and restart enigma, then do the autobouquets scan.
    • mrblue
      • 568
      #212
      I have installed this plugin, it does work well but it has created a second set of bouquets that are updated but has retained my old set aswell. I want it to work where it keeps my old set in tact, updating the channels within those bouquets without creating a newly updated set. I would also prefer that bouquet folders that Ive deleted and changed to remain in tact, like I always have sbo deleted and a couple of movies and sports channels deleted....
      I also keep my hd boquet and irish bouquet at the top of the list which I would like to have it stay that way..
      Is this not possible....
      Is there
      • invisiblelayer
        • May 2013
        • 7
        #213
        Fantastic plugin, many thanks works no problem on my vu+ solo
        • mrblue
          • 568
          #214
          Can someone pm me the developer website so I can make sure I have latest version and also for dvbsnoop, the version I have worked fine on my solo but crashed my duo and only way to sort it was a reflash
          • lincsat
            • 1228
            #215
            Start the app and press the about (Blue) button.
            • LraiZer
              • 126
              #216
              are you 100% sure your required reflash was caused by this plugin, as the plugin does not create or modify any files that would require a box reflash. in the worst case scenario, your bouquet files created by this plugin could have somehow become corrupt and simply uploading a new bouquet set or deleting your current bouquet set and running the plugin again would fix your box without requiring a reflash.
              lastest version is in post #135 of this thread
              dvbsnoop can be found HERE in post #7 of this thread!
              there were also some later patched files to fix ROI ITV channels, attached.
              you will also need a custom.txt as the one in the plugin is now out of date and will need a fix for the ALBA to BBC channel, attached.
              FYI
              the next version currently in development will not require dvbsnoop and is testing to be twice as fast as the current latest version, as all stream data reading/processing is now done directly by the plugin in memory.
              • LraiZer
                • 126
                #217
                yes, in AutoBouquets menu...
                turn default bouquet off,
                turn hd first bouquet off,
                now you can move/delete bouquets and these changes will be kept next time you run autobouquets.
                press remote: bouquets > favourites > menu > enable move mode
                move your all your bouquets to new required order.
                also while the hd first bouquet is turned off, if you delete the 28.2E UK Bouquet, the channels will start at next available channel position and all the placeholders with have been removed.
                press remote: bouquets > favourites > menu > remove entry
                • mrblue
                  • 568
                  #218
                  Working perfect mate, thanks for your help. Although Ive come to like the idea of going back to sky numbering as is my Dad as Ive just got him a vu solo and he would like the sky numbering as its what hes used to.
                  But when I press 301 it doesnt go to sky movies prem...is there another setting I need to change and does it still mean I can delete sbo bouquet. Not too bothered about having irish bouquet as im going to build a favourites folder. I presume this will always remain in tact....
                  • LraiZer
                    • 126
                    #219
                    the only way to rearrange your bouquets as you like but still have the sky official numbering keypress is to turn hd first off and defualt bouquets off as you have just done in the menu. but you must also leave the 28.2e UK Bouquet as the very first bouquet because this bouquet then contains all the channel placeholder skipping for the official number keypress to work. your other bouquets can only be placed and arranged how you like from the 2nd bouquet onwards. this first bouquet must remain as first bouquet. yes, you can delete sbo bouquet and favourites will be remain untouched.
                    • mrblue
                      • 568
                      #220
                      Anybody know if you can make a backup of the favourites bouquet. I have just completed an extensive favourites folder, took me a while. Would like to transfer it to my other two boxes as easy as possible......
                      • digicon
                        • 8261
                        #221
                        Download them from your box with Dreambox Edit and save to PC/Laptop
                        • mrblue
                          • 568
                          #222
                          I can ftp to my vu box and I see the file userbouquets.favourites.tv, Is it it just a matter of keeping this file for the other box...
                          • colinh1213
                            • Apr 2011
                            • 92
                            #223
                            when i load up this plug in it just crashes my box and i get the dreaded green screen , on an openpli image
                            • Radicaldoc
                              • Jul 2013
                              • 9
                              #224
                              anyone have a link they can PM me for developers site. please...thanks guys
                              • southpaw
                                • 2233
                                #225
                                have just downloaded the latest version from Pli download panel and must say this plugin is awesome, just select area and job done. 1st plugin I install on fresh builds for 28e now. btw, its nice to see LraiZer and Co working on E2 stuff, the development he has done on E1 commando image for dm500 is incredible, must have put thousands of hours in to it to squeeze every last drop out of old hardware. very much appreciated from me , if you can give us a link to your donate button I will gladly forward a bevvy for you mate
