AutoBouquets E2 28.2E plug-in
  • lincsat
    • 1228
    #256
    Restart Enigma2
    • Mattg79
      • Sep 2013
      • 6
      #257
      Tried that, but with no success, could i uninstall then reinstall the plugin or does it not work like that?
      • yamaha06
        #258
        hi im having this problem with the latest version on OE2.0 on all images.
        I have tried setting all file permissions to 755 via filezilla and did a manual scan on a 28.2e transponder.
        At the moment im using tsimage but did the same on dreamelite, newenigma, ozoon and merlin.
        My receiver is a 8000HD.
        Can anyone shed some light on this subject??
        • tonysmith
          • May 2012
          #259
          sky sports 1 gone today and performing nit scan won't bring it back !!! any idea
          • aidang
            • Nov 2012
            • 5
            #260
            Same as that. Triple Super Sunday!
            • aidang
              • Nov 2012
              • 5
              #261
              Its back
              • anthmatthews
                • Feb 2013
                • 100
                #262
                Yeah mine was back on for about half 1 ish - great plugin!
                • wimpey
                  • Dec 2011
                  • 7
                  #263
                  To remove the empty channels numbers from the autobouquets E2 go into autobouqets settings and down to pli placeholders and change to yes and Enable script checks to no . then press save or ok. these are the setting i use on a gigablue HD 800ue plus.
                  • rowl3y
                    • Feb 2011
                    • 44
                    #264
                    What file do I use for the Cloud Ibox ?
                    mips32el
                    mipsel
                    sh4
                    • max2741
                      • 18
                      #265
                      Trying to install this but I don't have media scanner to run the ipk file, tied to download the media scanner file through ts panel but it won't work, is there any other way to do this?
                      I'm using a dm800sehd clone, Enigma 2
                      • mtv1
                        The Stig PT
                        • 4413
                        #266
                        "here is AutoBouquets E2 28.2E Enigma2 Plugin for BETA TESTING!
                        this plugin has been coded with shell script backend so that it can be run on ANY box from the command line without python. it has a python enigma2 GUI so that you can select your area direct from remote in the plugins menu.
                        1) first make sure you have dvbsnoop in your /usr/bin/
                        2) drop the attached files onto engima2 box in the relevant folders.
                        make sure /usr/script/autobouquets_e2.sh file is executable (chmod 755)
                        3) reboot your box to load the new AutoBouquets E2 plugin into the Plugins menu
                        3) perform a scan on 28.2e satellite so that you have the latest lamedb service file
                        4) zap to an active channel on 28.2e so that dvbsnoop can read its stream data
                        5) select AutoBouquets E2 Plugin from plugins menu and then select your SD or HD area.
                        6) sit back and watch for 5 minutes as your local bouquets are read from the stream
                        7) Have fun with you new auto generated local bouquets
                        8) an autobouquets.log file is generated in the AutoBouquets plugin folder so that you can check processed Services, Positions and ChannelID's.
                        PS) dont forget to backup your current bouquet files first even though they will NOT be overwritten by this plugin.
                        PLUGIN and EXAMPLE of the resulting auto generated bouquets direct from the stream with region set as "Granada HD""
                        • monkified
                          • Aug 2012
                          • 5
                          #267
                          I've been trying for a few days to get this working, i have 2 boxes both dm800se with dream elite 3, one installed great and works flawless, my other box the channels are grey out when using auto bouquets and i can only access them when i go into the green button and choose the 28.2 sat, I've tried updating the xml and dvdsnoop, the tuner is set to 28.2, I've also put another image on and tried that but its still the same, could it be autobouquets just does not like my box or is it just something simple, i have also tried the rats plugin and its exactly the same with greyed out channels
                          any help would be appreciated
                          kev
                          • macdadi112
                            • May 2011
                            • 55
                            #268
                            Looks like a box issue unless of course you happen to install it on another image it don't work with.
                            • monkified
                              • Aug 2012
                              • 5
                              #269
                              thanks for fast reply macdadi its appreciated
                              i tried it on another image tonight and it was the same, then i tried using sgt flip-flops and it was still greyed out, so i new it had to be something with the tuner. in tuner config all was set correct 28.2,but in manual config it was set to 19.2 and 28.2 was not available for some reason, anyway i don't know what i did but just messed with manual tuner and it eventually showed 28.2, so i,m all happy, just with i had sussed that 3 flashes and about 10 service tunes ago
                              • YNA
                                • Jul 2010
                                Hello,
                                Can anyone tell me where the location of the"custom_swap.txt" file is please? I use I use DCC to access the root of the box. Many Thanks.
