AutoBouquets E2 28.2E plug-in
  • 00360362878
    • Mar 2010
    • 488
    #316
    Originally posted by dubdvd
    hi im looking for the latest bouquets for a dreambox 500s astra 28.2e im based in ireland but the UK is ok sorry im using open PLi
    Hi mate your better off flashing your box with commando image.
    look here http://www.digital-kaos.co.uk/forums...commando-15-00
    • 50pounds
      • Oct 2008
      • 36
      #317
      Originally posted by cocomo
      Ηι with DM800HD SE clone running Open Pli 4, I'd like to install AutoBouquets E2 plugin.
      I went to Menu-->Setup but I don't see-->Software Management-->Install local extension
      So what is the right move to have the AutoBouquets E2 plugin?
      Thank you in advance
      Harry.
      you need to download "filebrowser" in the plugins section on openpli
      once installed download AB e2 plugin then copy it to tmp folder using ftp
      also the ab is in the feed in download plugins (extensions) section!
      • 50pounds
        • Oct 2008
        • 36
        #318
        i cant get this to work on open pli 4.0 dm800sev2 :s does not even bring any bouquets up!
        • jayeshsondhi1
          • Jul 2015
          Originally posted by DMBoot
          /usr/lib/enigma2/python/Plugins/Extensions/AutoBouquets
          autobouquets
          autobouquets_e2.sh
          autolamedb
          set to 755
          Hi, what do you mean by this? How do I do this? I have gone to the directory location, but don't know what to do next. I have noticed that I can't find an autolamedb file too
          • shaunfree
            • 358
            #320
            right click each then properties then set permission to 755 cheers shaun
            • antrsuperstar
              • Sep 2012
              I have just downloaded and FTP'd this onto my Vu Duo on the latest Vix image from Hades but each time i try to run it, it crashes my box.
              Is there anything i need to do to help this run?
              • djrikstar
                • Nov 2011
                • 172
                #322
                Is anyone having issues with this plugin for the last 2 weeks or so never seems to update channels last couple of weeks me and a few mates have different boxes with this plugin on but same problem let us know. Thanks
                • hillway
                  • Oct 2010
                  #323
                  Hi Can anyone help just installed but when i hit green to run , i get error dvbsnoop not foud. ??? any ideas.
                  • digicon
                    • 8261
                    #324
                    To Install DVBsnoop, Telnet to your receiver using putty and enter in the command:
                    opkg update && opkg install dvbsnoop
                    • hillway
                      • Oct 2010
                      #325
                      Hi Many thanks for help tried that this is what i get , im using a vu duo and dreamboxuk image
                      vuduo login: root
                      Password:
                      root@vuduo:~# opkg update && opkg install dvbsnoop
                      Downloading http://downloads.pli-images.org/feed...ty/Packages.gz.
                      wget: server returned error: HTTP/1.1 404 Not Found
                      Downloading http://downloads.pli-images.org/feed...ll/Packages.gz.
                      Downloading http://downloads.pli-images.org/feed...el/Packages.gz.
                      Downloading http://downloads.pli-images.org/feed...uo/Packages.gz.
                      Collected errors:
                      * opkg_download: Failed to download http://downloads.pli-images.org/feed...ty/Packages.gz, wget returned 1.
                      * opkg_download: Failed to download http://downloads.pli-images.org/feed...ll/Packages.gz, wget returned 1.
                      * opkg_download: Failed to download http://downloads.pli-images.org/feed...el/Packages.gz, wget returned 1.
                      * opkg_download: Failed to download http://downloads.pli-images.org/feed...uo/Packages.gz, wget returned 1.
                      root@vuduo:~#
                      • lincsat
                        • 1228
                        #326
                        Those feeds are very old, try editing them to openpli4 or use a newer image
                        examples
                        http://downloads.pli-images.org/feeds/openpli-4/vuduo/Packages.gz
                        http://downloads.pli-images.org/feeds/openpli-4/mips32el/Packages.gz
                        • hillway
                          • Oct 2010
                          #327
                          examples
                          Thanks way over my head on how i update these links or if you can provide any pointers...
                          no point updating the image im happy with it its solid and runs well just to auto update the bouquets.
                          if someone can help out.
                          • shaunfree
                            • 358
                            #328
                            hi all not getting setanta hd with new scan, settings ok as i get bt hd + freeview hd any help please cheers shaun
                            • digicon
                              • 8261
                              #329
                              With Thanks to Abu Baniaz
                              2015-07-21Corrected Scotland East/West error
                              Added Wales region.
                              Added services and TP to "create lamedb" section.
                              Supplement file updated for new viewable HD channels
                              Swap file edited. Added BTSport/Euro HD swap. Target LCN now referenced first. Still works the same way.
                              Renamed autobouquetsreader.sh4 to "autobouquetsreader(sh4_receivers) to avoid any confusion between ".sh" and ".sh4".
                              If you have a receiver with a SH4 CPU eg Amiko, you still have to rename the file. Refer to lines 16-19 of readme file.
                              • 239546
                                • Jul 2015
                                • 6
                                #330
                                Can you please help me.
                                How do i download the bouquet can someone post the link? Does it work for Dreambox D800
                                Will include sports and movies?
