= MEDLOCK = SKY UK (28.2E) ENiGMA2 Bouquets And Picons - Updated Regularly.
  • mikeysauce
    • Mar 2012
    #31
    don't see the download link
    • digicon
      • 8261
      #32
      Oh! Dear try reading through the 3 pages of the thread and on page 2 you will see this here: http://www.digital-kaos.co.uk/forums...ml#post2005077
      • Medlock
        • 65
        #33
        If your referring to the "Irish Variation" channel list its not done, when its ready I'll post it.
        • happy_highlander
          • Aug 2010
          • 3535
          #34
          Stick the irish channels in a bouquet on there own and let them either use that or they can drag them across same as the other users do with their regional variations
          • Medlock
            • 65
            #35
            looks to be working OK.
            Looks like I've got it sorted, seems to be working OK. so hope to post a full channel list this weekend?
            • Medlock
              • 65
              #36
              UPDATE: 22/06/2013 - (SKY UK (28.2E) ENiGMA2 Bouquets And Picons)
              UPDATE: 22/06/2013
              Updated Channel List Bouquets and Picons - 22/06/13
              12 new updated Picons added also
              This update has a "Irish Variations" Bouquet.
              Not sure of all the Irish variations channels, Comedy Central`s etc, so if those that use them want to post which they are I'll add then next time round.
              Channel listings and bouquets are positioned and in keeping with the current Sky HD layout.
              (Edit Your Own BBC & ITV Region Channels In DreamboxEDIT)
              MEDLOCK - "Sgt BrickTop"
              • jewels01
                • May 2010
                • 11
                #37
                Stiil Disney hd problem and sky select?
                • Medlock
                  • 65
                  #38
                  Both channels working fine from where I am.
                  • jewels01
                    • May 2010
                    • 11
                    #39
                    Not sure what Im doing wrong, sd works fine just the hd version even when I click all channels and select from there. Any ideas? ps you doing a good job! (ex B16 MCC user)
                    • Medlock
                      • 65
                      #40
                      Maybe worth going back to your previous channel list just to make sure all was working prior or if others are having the same problem they maybe able to help?
                      • Nurspec
                        • Jun 2013
                        #41
                        I have the same problem, has only stared happening since i installed the 28.2 Auto Bouquet Plugin by Lraizer.
                        • happy_highlander
                          • Aug 2010
                          • 3535
                          #42
                          Not meaning to intrude on your thread Medlock but can you two lads that are having problems with the two channels check the frequency and pids and more importantly the fec to see if they match the kos settings or post them on thread and I'll check them. If they do match do a single transponder scan. The channels should then work but the fec may have changed. Don't ask me why it does it but since changing my setup to using a diseqc switch itv hd will only work with different fec on same tp settings.
                          • jewels01
                            • May 2010
                            • 11
                            #43
                            Would I supply this by going into dreambox edit to view bouquet or do I get the information another way for you. Many thanks for taking the time to help.
                            • jewels01
                              • May 2010
                              • 11
                              #44
                              My Disney HD is 12168 V29500 3/4 QPSK if that helps
                              • happy_highlander
                                • Aug 2010
                                • 3535
                                #45
                                Those settings are correct. You haven't given me the pid but no matter. On the same transponder you have sky modern greats sky drama sky scifi/horror and sky comedy all hd. If you can see these then the video pid must be wrong for Disney. If you do a single transponder scan on this transponder it should sort Disney for you.
