== ALL NEW = SKY UK ENiGMA2 Bouquets And Picons ==
NORTHWEST / GRANADA REGION (Edit Your Own BBC & ITV Regional Channels To Suit Your Needs In Dreamboxedit)
Firstly...... I undertake to do this for my own benefit but will contribute what I have to assist and benefit others.
I've decided the best way forward to continue with regular ENiGMA2 and Picons bouquet updates is to start over from scratch, the channel list has been totally rebuilt, channel frequency and interactive updates should be better updated and more consistent? however I don't use interactive services so am unable to verify them, I'm also limited to a "DM800HD" box for all testing and configuration, so therefore I'm only aware of issues relating to my own image and equipment.
I've also decided to continue with the menu look of SGTFlipFlop's original bouquet, this however does require more work and all SKY channels will follow SKY UK channel format listings, they are at present unnumbered with the SKY channel numbers, only named as this seems to save confusion when updating, however that may change in the future?
With the exception of some of "SGTFlipFlop's" old Picons, it's all new, I've re-done and updated around 100 new Picons to date since the end of May 2013 and I'll continue over time to update the Picons with new images when needed using my own style.
So fingers crossed that these new bouquets are all working OK?
I appreciate there will be errors initially which I have overlooked, so please report and I'll do what I can to correct and update where necessary.
MEDLOCK - "Sgt BrickTop"
