having probs with bouquetes
  • billy2
    • 1381
    hi guys anyone know why iam have problems loading bouquets to dreambox 800hd. all settings are right as far as I can see using E2 settings
    Try unticking the auto reload settings and the upload picons so its just doing the channel list and nothing else you can always reload after as it takes a second to press another button.
    Might be worth trying Vhannibals bouquet just to rule out the settings in DBE
    • billy2
      • 1381
      thanks very much for your reply m8 in the end I had to reflash the box all working now , only think is now I cant update TSmedia I keep getting a update failed 404 not found ??? img iam using is DreamboxUK_v2.1.2_BL84b_DM800_Backup-2013-05-31 that has TSmedia 2.3 on it when I go to update it tells me there is a new update 4.9 when I press download I get the above error ???
        There is a newer version here 4.5 thanks to poster: http://www.digital-kaos.co.uk/forums...4/#post2146229 i would un-install your V2.3 and try this version to upgrade from as it could be the 2.3 version is too old to update from just a guess. Or it could be that the download server for the latest version is down
        Cant be much more help buddy as i dont use TSmedia
        Good Luck
