Have a try of these if you have a combo linux box
I have used my normal E2 uk and 4 sat euro but added cable to the list with some new favorites that are a bit of hybrid set with channels from both sat and cable in the same favorite. Obvious example is the hybrid movies favorite which has all the sd movies from sat with the hd from cable.
Euro Sats are 13, 19.2, 23.5 and 28.2 you may need to ftp the cable.xml into your box seperately as dbe doesn't always send it. If you need to know where to put it check the settings in dbe for where your satellite.xml gets sent
Latest Lists are at the end of the thread or just press Here to jump straight to them.
) and will be plugging in over the next week so will check them out and try to load and see where I get to..
