SGTFlipFlop SKYUK Bouquets - Updated Regularly
  • SGTFlipFlop
    • Sep 2009
    • 1002
    Latest Bouquets always at the end of the thread or click this link
    11th December 2013 (Latest Bouquets)
    http://www.digital-kaos.co.uk/forums...ml#post2171809
  • damiensk
    • Apr 2010
    • 201
    asking cos i dont know,
    u have 2 d/l 4 dm800 e2, apart from 1 being a bigger file than the other, can u tell me what is the diffrence.
    does multi mean for more than 1 satallite?
    • Wingnut
      • 376
      if i ftp the multi one sat must i always have to do a full scan on each sat after its send to box?thanks
      • damiensk
        • Apr 2010
        • 201
        ive got the answer to my own question, so sorted now.
        i dont think u have to do a full scan one each sat,
        can u actually get every sat in that list?
        i know i cant.
        • RuberDuck
          • 1724
          i know i cant.
          erm the whole point of a bouquet pack is that once loaded you dont have to scan any thing as the bouquet contains all the necessary information etc.
          if you did want to go all OCD you could load a new satellites.xml file onto the box every other week and do a rescan of any satellites you used regularly, however that would be a bit pointless as SGTFlipFlop updates his packs very often.
          • lombard
            • 793
            ITV 2 HD comes up as DVB service and says tuner failed ? using DM800 with inline amp, ?
            THanks
            • SGTFlipFlop
              • Sep 2009
              • 1002
              THanks
              I've fixed that for the next update, When I imported the channel it has changed the Symbolrate and FEC, Should be 29500 / 3/4
              • lombard
                • 793
                I did a manual scan on that and it starting working
                • SGTFlipFlop
                  • Sep 2009
                  • 1002
                  Not sure why it changed when importing, Something I need to keep an eye on
                  • RuberDuck
                    • 1724
                    yeah the same thing has happened with a few different bouquet packs by different teams. not sure why though.
                    • SGTFlipFlop
                      • Sep 2009
                      • 1002
                      There should be an update out, Later tonight or tomorrow morning
                      • mr e
                        • 20
                        hi guys,i'm a noob ,i'm struggling with putting these bouquets onto my dm 800.i'm trying to use dcc to transfer them over.I cant get the file to go over,any ideas?
                        • RuberDuck
                          • 1724
                          thats your problem mate, you dont use DCC you use DBE aka DreamBoxedit.
                          • SGTFlipFlop
                            • Sep 2009
                            • 1002
                            Updates: 4th October 2010
                            DreamboxEdit 3.1.0.2 Used (Recommended)
                            Updates: 30th September 2010
                            DM800 Bouquet
                            40 n Naughty (New Channel)
                            Disney XD HD (New Channel)
                            Sikh TV (New Channel)
                            Fixed ITV2 HD
                            Removed Channels
                            Faith World +1
                            Picons
                            Will update them tomorrow
                            ** Edit your own BBC & ITV Regional channels to suit your needs in DreamboxEdit (If you are from Ireland, I've renamed all Irish channels so easy for you to find) **
                            Also added Picons for Sky UK (Base set from Picon4U) and the rest updated by myself
                            Use any FTP client, DCC for example, to transfer the picon directory
                            to one of the following paths on Flash, HDD, CF or USB respectively:
                            /usr/share/enigma2
                            NOT recommended, because of limited capacity of the flash memory
                            /media/hdd
                            HDD will keep running indefinitely and may affect image performance
                            /media/cf
                            Recommended if CF available and successfully mounted (8000/800)
                            /media/usb
                            Recommended if USB available and successfully mounted (8000/800)
                            Picon will display immediately on zapping, no further setup required!
                            Please keep this thread clean, Use the Thanks button rather than posting on the thread, Details on how to via DreamboxEdit is widely available on the net.
                            • SGTFlipFlop
                              • Sep 2009
                              • 1002
                              Picons now updated
