SGTFlipFlop SKYUK Bouquets - Updated Regularly
  • SGTFlipFlop
    replied
    Originally posted by smirnoff_rules
    with the new dream box edit u can add picons in there to and they load into the program and then to the box too
    Been there for ages mate
    Leave a comment:
  • smirnoff_rules
    replied
    Leave a comment:
  • SGTFlipFlop
    replied
    Here is the latest update
    DreamboxEdit 5.0.1.0 Used (Recommended) Guide Here
    Enigma 1 = Dreambox 500, 600, 7020 | TechnoMate 500, 500 Super, 600 | Blade Media 500
    Enigma 2 = Dreambox 800(SE), 8000, 500HD, 7020HD | VU Uno, Solo, Duo, Ultimo | ET 5000, 6000, 9000, 9100, 9200 | TechnoMate 500HD, 800
    Updates: 28th March 2012
    Bouquet Updates
    Body In Balance Renamed To LiveXXXBabes
    CBS Reality (New Frequency)
    Channel 4 HD (Fixed)
    ITV Meridian SE (Updated Frequency)
    ITV Tyne Tees (Updated Frequency)
    Sky Atlantic Ireland (New Frequency)
    Sky Sports 1 For Pubs (New Frequency)
    Sky Sports 3 For Pubs (New Frequency)
    Sky Sports 4 For Pubs (New Frequency)
    Sky Sports Interactive (Fixed Few Channels)
    Removed Channels
    CBS Reality
    Current TV
    ITV Meridian E
    ITV Meridian SE
    ITV Tyne Tees S
    Picons
    Updated newest channels
    These bouquets are positioned identical to the Sky Box, All that is different is the numbering which I find to be very messy when done so I leave it how it is. Enjoy a neat up to date bouquet.
    I will be doing Enigma2 Multi Bouquet, But will not for Enigma1 as it takes too long to remove every HD channel from all satellites, Easily too do yourself if you have the time.
    ** Edit your own BBC & ITV Regional channels to suit your needs in DreamboxEdit (If you are from Ireland, I've renamed all Irish channels so easy for you to find) **
    Also added Picons for Sky UK,
    All correctly mapped and a few obscure ones missing only
    Use any FTP client, DCC for example, to transfer the picon directory to
    one of the following paths on Flash, HDD, CF or USB respectively:
    /usr/share/enigma2
    NOT recommended, because of limited capacity of the flash memory
    /media/hdd
    HDD will keep running indefinitely and may affect image performance
    /media/cf
    Recommended if CF available and successfully mounted (8000/800)
    /media/usb
    Recommended if USB available and successfully mounted (8000/800)
    Picon will display immediately on zapping, no further setup required!
    Always remove old picons from Dreambox before uploading new ones,
    Sometimes they don't overwrite correctly
    Please keep this thread clean, Use the Thanks button rather than posting on the thread
    Leave a comment:
  • guinnesscobra
    replied
    Thanks sgtflipflop. Will do that.
    Leave a comment:
  • SGTFlipFlop
    replied
    Originally posted by micflair
    Its moved freq. mate.. hang on in there till the next update.
    A quick scan fixes it
    Leave a comment:
  • micflair
    replied
    Originally posted by guinnesscobra
    Hi - suddenly this evening, my channel 4 hd doesnt work anymore. It says "Tune failed". I reloaded the latest bouquets and rebooted. No difference - any help would be appreciated. Thanks.
    Leave a comment:
  • guinnesscobra
    replied
    Missing Channel 4 HD
    Leave a comment:
  • bunderson
    replied
    Uploaded picon pack to HDD, had to reboot Enigma before they showed (might be worth adding to your guide).
    Many thanks for all your hard work here, I'm very grateful
    Al.
    Leave a comment:
  • jona241085
    replied
    does the enigma 1 version have sky 1 as had problem with it when downloaded enigma 2 version on another forum
    Leave a comment:
  • tmontana
    Guest replied
    problem solved
    Leave a comment:
  • tich77
    replied
    No ITV1 in bouquets
    ITV (1) appears to be missing from the bouquet? Surely cant be right. Downloaded, extracted, ftp'd up via Dreamboxedit... but no entry for ITV in any section. ITV2 and 3 appear.
    What is the entry number?
    Under Entertainments I have
    62 BBC One
    63 BBC Two
    64 Channel 4
    65 Channel 5
    66 Sky 1 HD
    75 BBC Three
    76 BBC Four
    77 ITV2 HD
    78 ITV3HD
    BTW, Pick appears in my lists :-)
    Many thanks
    edit. Oh donkey - Just realised that I have to ADD the ITV region of my choice... DOH!
    Leave a comment:
  • emzemz
    replied
    thanks working well
    Leave a comment:
  • pace508
    replied
    i was wondering what is CCcam channel info is for and where do you install it
    Leave a comment:
  • mbc0
    replied
    Cheers for the reply, I have been searching all day & must admit I haven't found anything by Sgt Flip Flop but various other guides, I am still trying to get cross epg working, all installed it downloads all the channels & compiles etc but still nothing displayed :-( if you do find it I would appreciate a link!
    Cheers
    Leave a comment:
  • D1SHABBA
    replied
    Originally posted by mbc0
    Hi Guys,
    I am a new user & have got a DM800 with Enigma 2. I have now successfully got this great Bouquet (Thank you Sgt Flip Flop!) but there is no program information when I look through the channels until I select a channel & then the info is there. How do I get a 7 day guide like a normal freeview/freesat/sly box?
    Many Thanks
    If you do a search mate there is a very step bu step guide and I believe it is by sgtflipflop....if u dnt find it let me know cus I did mine not long ago and it is very useful
    Leave a comment:
