Hi as I was used to the pliJade image I found this a bit different so have scribbled a help file.
Hope it helps
Hope it helps
Softcam ******* Commando for DM500S is FTA, always has been, and always will be. However, we do carry a useful and highly intelligent Softcam Menu in the Commando Extras Menu- BLUE > Menu > RED Some people like to mess around with LAN Multi-Room setups, but struggle on where to place the added files necessary for testing and educational use. /var/bin/emu/CCcam is where the cam itself goes, and that is EXACTLY what it needs to be named, otherwise the Softcam menu will not recognize it. (Linux filenames are cAsE sensitive, remember!) It does not need to be set to chmod 755 as the menu hard coding does this for you. You'll also need /var/etc/CCcam.cfg (again correctly named, as shown). Some users wish to run oscam AND CCcam together, but need oscam to always load first, in order that it grabs priority over CCcam for the CardReader. Your wish is our command! LraiZer has tweaked Mohoush's original softcam nenu code logic so that this cam start order should now (in theory) be obeyed. Feedback awaited please... nb: For mgcamd or evocamd users only. Please note that /lib/libcrypto.so.0.9.7 is no longer embedded in root as standard. This file is now packaged loose in the release rar archive for adding into the /var/lib folder instead, where it will work fine.
