14.6 image (getepg locks up the box)
  • spudorange
    • 242
    Hi have quite a few of these dreambox 500's pass my way and I have changed them all over to 14.6 from pli, mainly because of the excellent epg.
    The problem I have on 2 boxes is as follows.
    Box 1 starts to "loadgetepg" and finishes in 3 seconds, press ok. Box is then locked solid, the remote does activate the led on box
    but the box does not respond without a hard reboot.
    Box 2 Exactly the same as above except it does get the epg then locks the same.
    I have had the first problem before with it getting epg in seconds (so not actually getting it) but not had the locking up problem.
    Flashing does not help, although obviously I can try again.
    appreciate if anyone could share some light
  • smirnoff_rules
    • 8603
    there is an option to change tuner drivers in services l think , might be an idea changing that
    • spudorange
      • 242
      looked for it but can not find it
      any ideas please
      • smirnoff_rules
        • 8603
        heres my backup from birmingham so u might have to change area http://www.filedropper.com/c146-dm500-backup channels already scanned and timers set to upload epg at 3 in the morning and go onto standby
        • spudorange
          • 242
          I have my setup perfect on them but your efforts are appreciated (the only plugin I use is the "loadgetepg" one set for 4am)
          I just need to stop this lock up as it's the very thing I want (the epg) that is causing the problem.
          can not find a setting for tuner either in case it is that
          • smirnoff_rules
            • 8603
            its in setting but looks like theres been a change from 14.5
            • spudorange
              • 242
              can't find the blessed thing
              • PaphosAL
                Old Git
                • 1064
                The box where GetEPG apparently cycles in only 3 secs, can you telnet in and type the command getepg <enter> please? Then observe console output to see if any error message is reported,
                Support for users to experiment with different head.ko drivers in /var/driver folder came out with Commando 14 but was never a GUI menu item. LraiZer even included error trapping code to prevent the Gemini 'clone bomb' driver from being inadvertently loaded. But this is not an epg issue, more to do with random blackouts if the box is equipped with a crap Philips tuner, rather than Alps -S
                You can see which type of tuner you have with BLUE > MENU > YELLOW > YELLOW and then scroll down to the last few lines where it says nim=
                Back to the GetEPG. In FTP go to the /var/bin folder and check these scripts exist and are all 755
                getepg
                getepg-msg
                getepg-now
                miniops
                weekepgset
                Are all these files dated 23/06/2012 or have any of them been edited with a crap text editor like Wordpad, Notepad or the FTP Internal editor? If everything seems in order, my guess is that this is a corrupted flash.
                Cheers- AL
                • spudorange
                  • 242
                  can not telnet in I get busybox v1.17 etc error after I get to dreambox login and enter "root", If I put in "dreambox" for example it then asks for password and I put dreambox in it says incorrect password.
                  SO entering correct "root" puts me into that busybox error.
                  Going to replash and report back
                  incidentally if the 755 you mean is file size then mine are wrong, correct date though.
                  mine show
                  getepg 318
                  getepg-msg 369
                  getepg-now 174
                  miniops 3k
                  weekepgset 2k
                  Back once flashed
                  ta
                  getepg
                  getepg-msg
                  getepg-now
                  miniops
                  weekepgset
                  Cheers- AL
                  • spudorange
                    • 242
                    Must have been as you say a bad flash.
                    after getting epg this time I noticed it said remote control reactivated and everything is responding now
                    thanks to all
                    • PaphosAL
                      Old Git
                      • 1064
                      Nowt to do with file sizes in bytes, 755 means chmod 755 meaning it's got executable binary or script permissions, as opposed to the default chmod 644 (which linux will refuse to run)
                      So it was a bad flash after all. Same probably applies to the second box as well.
                      You guys have to realize that what LraiZer has created here with GetEPG is sheer perfection personified. It does take 3 to 4 minutes, which is why we suggest running it during the ads. And yes, during processing, he locks out the R/C, as if this was pressed, it would screw it!!
                      But better still, set it up as a daily plugin Timer, like it seems you're doing. Or even better, set it to run after a Reboot, then set a daily Reboot plugin (or Shutdown) timer. We've found since C14.6 release that the "Timer Type = Shutdown" actually does a controlled Menu reboot of the box, the DM500 having no shutdown mode as such, like the old dBox2 did.
                      So we're revamping this aspect for the C14.7 issue coming in Autumn...
                      Cheers- AL
                      • spudorange
                        • 242
                        thanks for that info and yes, absolutely agree
                        Cracking bit (lot) of work, it is SO SO much better than pli now the epg works the way it does
                        Cheers- AL
